7.5 GAME - 10 Secondï
To challenge your concentration, follow me next to make a game device. Make a magic wand by connecting the tilt switch with a stick. When you shake the wand, the 4-digit segment display will start counting, and when you shake it again, it will stop counting. In order to win, you must keep the displayed count at 10.00. You can play the game with your friends to see who is the time wizard.
Kepler Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
5(4-220Ω, 1-10KΩ) |
7 |
8 |
Schematic
This circuit is based on 5.3 Time Counter with the addition of a tilt switch.
GP16 is high when the tilt switch is upright; low when tilted.
Open the
7.5_game_10_second.pyfile under the path ofkepler-kit-main/micropythonor copy this code into Thonny, then click âRun Current Scriptâ or simply press F5 to run it.Donât forget to click on the âMicroPython (Raspberry Pi Pico)â interpreter in the bottom right corner.
For detailed tutorials, please refer to Open and Run Code Directly.
import machine
# 7-segment display codes for digits 0-9, using hexadecimal to represent LED segments
SEGCODE = [0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f]
# Define pins for shift register communication (74HC595)
sdi = machine.Pin(18, machine.Pin.OUT) # Serial Data Input
rclk = machine.Pin(19, machine.Pin.OUT) # Register Clock (Latch)
srclk = machine.Pin(20, machine.Pin.OUT) # Shift Register Clock
# Initialize list to store 4 digit control pins
placePin = []
# Define control pins for each of the four digits (common anodes)
pin = [10,13,12,11] # Pin numbers for the 4-digit display
for i in range(4):
placePin.append(None) # Reserve space in list
placePin[i] = machine.Pin(pin[i], machine.Pin.OUT) # Initialize pin as output
# Function to select which digit (0-3) to display by controlling the common anode pins
def pickDigit(digit):
for i in range(4):
placePin[i].value(1) # Turn off all digits
placePin[digit].value(0) # Turn on the selected digit
# Function to clear the display by sending '0x00' to the shift register
def clearDisplay():
hc595_shift(0x00)
# Function to send data to the shift register (74HC595)
def hc595_shift(dat):
rclk.low() # Pull latch low to prepare for data shifting
time.sleep_us(200) # Small delay for timing stability
for bit in range(7, -1, -1): # Loop through each bit (MSB first)
srclk.low() # Prepare to send the next bit
time.sleep_us(200)
value = 1 & (dat >> bit) # Extract the current bit from the data
sdi.value(value) # Set the data line to the current bit value
time.sleep_us(200)
srclk.high() # Pulse the shift clock to store the bit in the register
time.sleep_us(200)
time.sleep_us(200)
rclk.high() # Pulse the register clock to move the data to the output
# Function to display a number on the 7-segment display
# This function breaks down the number into its individual digits and displays them one at a time
def display(num):
pickDigit(0) # Select the units place
hc595_shift(SEGCODE[num % 10]) # Display units
pickDigit(1) # Select the tens place
hc595_shift(SEGCODE[num % 100 // 10]) # Display tens
pickDigit(2) # Select the hundreds place
hc595_shift(SEGCODE[num % 1000 // 100] + 0x80) # Display hundreds (with decimal point)
pickDigit(3) # Select the thousands place
hc595_shift(SEGCODE[num % 10000 // 1000]) # Display thousands
# Initialize the tilt switch sensor on pin 16
tilt_switch = machine.Pin(16, machine.Pin.IN)
# Boolean flag to control whether the counting should continue
count_flag = False
# Interrupt handler for the tilt switch, toggles the counting flag on each trigger
def shake(pin):
global timeStart, count_flag
count_flag = not count_flag # Toggle the counting state
if count_flag == True:
timeStart = time.ticks_ms() # Record the time when counting starts
# Set up an interrupt on the tilt switch to detect shaking and call the shake() function
tilt_switch.irq(trigger=machine.Pin.IRQ_RISING, handler=shake)
# Initialize the count variable to zero
count = 0
# Main loop to continuously update the display based on the elapsed time since the tilt switch was triggered
count = int((time.ticks_ms() - timeStart) / 10) # Calculate the count in tenths of a second
display(count) # Update the display with the current count
The 4-digit 7-segment display will begin counting when you shake the wand, and will stop counting when you shake it again. You win if you manage to keep the displayed count at 10.00. The game will continue after one more shake.
