7.7 Guess Numberï
Guessing Numbers is a fun party game where you and your friends input numbers (0-99). With each input of the number, the range will shrink until a player answers the riddle correctly. Then the player is defeated and punished.
As an example, if the lucky number is 51, which the players cannot see, and the player 1 inputs 50, the prompt changes to 50 - 99; if the player 2 inputs 70, the range changes to 50 - 70; if the player 3 inputs 51, the player is unlucky. In this case, numbers are inputted through the keypad, and outcomes are displayed on a LCD screen.
Kepler Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
4(10KΩ) |
7 |
Schematic
This circuit is based on 4.2 4x4 Keypad with the addition of an I2C LCD1602 to display the pressed keys.
To make the wiring easier, in the above diagram, the column row of the matrix keyboard and the 10K resistors are inserted into the holes where G10 ~ G13 are located at the same time.
Open the
7.7_game_guess_number.pyfile under the path ofkepler-kit-main/micropythonor copy this code into Thonny, then click âRun Current Scriptâ or simply press F5 to run it.Donât forget to click on the âMicroPython (Raspberry Pi Pico)â interpreter in the bottom right corner.
For detailed tutorials, please refer to Open and Run Code Directly.
from lcd1602 import LCD
from machine import I2C, Pin
import urandom
# Initialize I2C communication for the LCD1602 display
# Create an LCD object for controlling the LCD1602 display
lcd = LCD(i2c)
# Keypad character mapping for a 4x4 matrix keypad
characters = [["1", "2", "3", "A"],
["4", "5", "6", "B"],
["7", "8", "9", "C"],
["*", "0", "#", "D"]]
# Define row pins for the keypad
pin = [21, 20, 19, 18]
row = []
for i in range(4):
row.append(None)
row[i] = machine.Pin(pin[i], machine.Pin.OUT) # Set row pins as output
# Define column pins for the keypad
pin = [13, 12, 11, 10]
col = []
for i in range(4):
col.append(None)
col[i] = machine.Pin(pin[i], machine.Pin.IN) # Set column pins as input
# Function to read a key from the keypad
def readKey():
key = []
for i in range(4):
row[i].high() # Set the row pin high
for j in range(4):
if col[j].value() == 1: # Check if any column is pressed
key.append(characters[i][j]) # Record the corresponding key
row[i].low() # Set the row pin low
if key == []:
return None # Return None if no key is pressed
return key # Return the pressed key
# Initialize and reset the game variables (random pointValue, upper/lower limits)
def init_new_value():
global pointValue, upper, count, lower
pointValue = int(urandom.uniform(0, 99)) # Generate a random number between 0 and 99
print(pointValue) # Print the target number (for debugging)
upper = 99 # Set initial upper bound
lower = 0 # Set initial lower bound
count = 0 # Reset the player's guess count
return False # Indicate that the game has not ended
# Function to display the game information on the LCD
# If the player has guessed correctly, show "GAME OVER"
# Otherwise, show the current guess and range
def lcd_show(result):
lcd.clear() # Clear the LCD display
if result == True: # If the player guessed correctly
string = "GAME OVER!\n"
string += "Point is " + str(pointValue) # Display the correct number
string = "Enter number: " + str(count) + "\n" # Show the player's current guess
string += str(lower) + " < Point < " + str(upper) # Show the range of possible values
lcd.message(string) # Send the string to the LCD
return
# Process the player's guess and update the upper or lower bound
# If the guess matches the pointValue, return True to indicate the game is over
# Otherwise, update the bounds and return False
def number_processing():
global upper, count, lower
if count > pointValue:
if count < upper:
upper = count # Update the upper bound if the guess is too high
elif count < pointValue:
if count > lower:
lower = count # Update the lower bound if the guess is too low
elif count == pointValue:
return True # Return True if the guess matches the pointValue
count = 0 # Reset the guess count for the next attempt
return False
## Main game setup and loop
# Display a welcome message and prompt the user to press 'A' to start
string = "Press A to Start!"
lcd.message(string)
result = init_new_value() # Initialize game variables
# Main loop to handle keypad input and update the display
last_key = None
current_key = readKey() # Read the current key pressed
if current_key == last_key:
continue # Skip processing if the same key is still pressed
last_key = current_key # Update the last pressed key
if current_key != None:
# If 'A' is pressed, restart the game with a new target number
if current_key == ["A"]:
# If 'D' is pressed, check if the current guess is correct
elif current_key == ["D"]:
result = number_processing()
# If a number is pressed and the count is less than 10 digits
elif current_key[0] in list("1234567890") and count < 10:
count = count * 10 + int(current_key[0]) # Add the digit to the current guess
lcd_show(result) # Update the LCD with the current game state
time.sleep(0.1) # Small delay for key debounce
After the code runs, press
Ato start the game. A random numberpointis produced but not displayed on the LCD, and what you need to do is to guess it.The number you have typed appears at the end of the first line till the final calculation is finished. (Press
Dto start the comparation.)The number range of
pointis displayed on the second line. And you must type the number within the range.When you type a number, the range narrows; if you got the lucky number luckily or unluckily, there will appear
GAME OVER!.
If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
