7.6 Traffic Lightï
Traffic Light is a signal device located at roadway intersections, crosswalks and other locations to control the flow of traffic.
Traffic signals are standardized by the Vienna Convention on Road Signs and Signals. Provides users with the right-of-way by alternating LEDs in three standard colors.
Red light: Traffic should stop if it sees a flashing red light, equivalent to a stop sign.
Yellow light: A warning signal is about to turn red. Yellow lights are interpreted differently in different countries (regions).
Green light: Allows traffic to move in the indicated direction.
In this project, we will use three colors of LEDs to implement traffic light changes and a 4-digit 7-segment display to show the time of each traffic state.
Kepler Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
7(220Ω) |
7 |
8 |
Schematic
This circuit is based on the 5.3 Time Counter with the addition of 3 LEDs.
The 3 red, yellow and green LEDs are connected to GP7~GP9 respectively.
Open the
7.6_traffic_light.pyfile under the path ofkepler-kit-main/micropythonor copy this code into Thonny, then click âRun Current Scriptâ or simply press F5 to run it.Donât forget to click on the âMicroPython (Raspberry Pi Pico)â interpreter in the bottom right corner.
For detailed tutorials, please refer to Open and Run Code Directly.
import machine
from machine import Timer
# Define the duration for each traffic light color in seconds [Green, Yellow, Red]
lightTime = [30, 5, 30]
# 7-segment display codes for digits 0-9, using hexadecimal to represent LED segments
SEGCODE = [0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f]
# Initialize pins for shift register communication (74HC595)
sdi = machine.Pin(18, machine.Pin.OUT) # Serial Data Input
rclk = machine.Pin(19, machine.Pin.OUT) # Register Clock (Latch)
srclk = machine.Pin(20, machine.Pin.OUT) # Shift Register Clock
# Initialize list to store 4 digit control pins for the 7-segment display
placePin = []
pin = [10, 13, 12, 11] # Pin numbers for the 4-digit display
for i in range(4):
placePin.append(None) # Reserve space in list
placePin[i] = machine.Pin(pin[i], machine.Pin.OUT) # Initialize pins as output
# Function to select which digit (0-3) to display by controlling the common anode pins
def pickDigit(digit):
for i in range(4):
placePin[i].value(1) # Turn off all digits
placePin[digit].value(0) # Turn on the selected digit
# Function to clear the display by sending '0x00' to the shift register
def clearDisplay():
hc595_shift(0x00)
# Function to send data to the shift register (74HC595)
def hc595_shift(dat):
rclk.low() # Pull latch low to prepare for data shifting
time.sleep_us(200) # Small delay for timing stability
for bit in range(7, -1, -1): # Loop through each bit (MSB first)
srclk.low() # Prepare to send the next bit
time.sleep_us(200)
value = 1 & (dat >> bit) # Extract the current bit from the data
sdi.value(value) # Set the data line to the current bit value
time.sleep_us(200)
srclk.high() # Pulse the shift clock to store the bit in the register
time.sleep_us(200)
time.sleep_us(200)
rclk.high() # Pulse the register clock to move the data to the output
# Function to display a number on the 7-segment display
# This function breaks down the number into its individual digits and displays them
def display(num):
pickDigit(0) # Select the units place
hc595_shift(SEGCODE[num % 10]) # Display units
pickDigit(1) # Select the tens place
hc595_shift(SEGCODE[num % 100 // 10]) # Display tens
pickDigit(2) # Select the hundreds place
hc595_shift(SEGCODE[num % 1000 // 100]) # Display hundreds
pickDigit(3) # Select the thousands place
hc595_shift(SEGCODE[num % 10000 // 1000]) # Display thousands
# Setup for traffic light LEDs (Red, Yellow, Green)
# LEDs are connected to pins 9 (Green), 8 (Yellow), and 7 (Red)
pin = [7, 8, 9] # LED pin numbers
led = []
for i in range(3):
led.append(None) # Reserve space in list
led[i] = machine.Pin(pin[i], machine.Pin.OUT) # Initialize each pin as output for LEDs
# Function to turn on the correct LED based on the current state
# 0 = Green, 1 = Yellow, 2 = Red
def lightup(state):
for i in range(3):
led[i].value(0) # Turn off all LEDs
led[state].value(1) # Turn on the selected LED (Green, Yellow, or Red)
# Timer-related variables
counter = 0 # Counter for the remaining time
color_state = 0 # Current state of the traffic light (0 = Green, 1 = Yellow, 2 = Red)
# Timer interrupt callback to update the traffic light state and counter
def time_count(ev):
global counter, color_state
counter -= 1 # Decrease the counter by 1 second
if counter <= 0: # If the counter reaches zero, switch to the next light color
color_state = (color_state + 1) % 3 # Cycle through Green, Yellow, and Red
counter = lightTime[color_state] # Reset counter based on the new color's duration
# Initialize a timer to call the time_count function every 1 second (1000ms)
tim = Timer(period=1000, mode=Timer.PERIODIC, callback=time_count)
# Main loop to update the 7-segment display and traffic light LEDs
display(counter) # Update the display with the remaining time
lightup(color_state) # Update the traffic light LEDs based on the current color
When the code runs, the green LED stays on for 30 seconds, the yellow LED stays on for 5 seconds, and the green LED stays on for 30 seconds.
