7.10 Reversing Aidï
This project uses an LED, a buzzer and an ultrasonic module to create a reversing assist system. We can put it on a remote control car to simulate the the actual process of reversing a car into a garage.
Kepler Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
1(S8050) |
2(1KΩ, 220Ω) |
7 |
Active Buzzer |
8 |
9 |
Schematic
Open the
7.10_reversing_aid.pyfile under the path ofkepler-kit-main/micropythonor copy this code into Thonny, then click âRun Current Scriptâ or simply press F5 to run it.Donât forget to click on the âMicroPython (Raspberry Pi Pico)â interpreter in the bottom right corner.
For detailed tutorials, please refer to Open and Run Code Directly.
import machine
# Initialize pins for the buzzer and LED
buzzer = machine.Pin(15, machine.Pin.OUT) # Buzzer on pin 15
led = machine.Pin(14, machine.Pin.OUT) # LED on pin 14
# Initialize pins for the ultrasonic sensor (HC-SR04)
TRIG = machine.Pin(17, machine.Pin.OUT) # Trigger pin for the ultrasonic sensor
ECHO = machine.Pin(16, machine.Pin.IN) # Echo pin for the ultrasonic sensor
dis = 100 # Global variable to store the distance
# Function to measure distance using the ultrasonic sensor
def distance():
TRIG.low()
time.sleep_us(2)
TRIG.high()
time.sleep_us(10)
TRIG.low()
timeout_start = time.ticks_us() # Use microseconds for more precision
# Wait for ECHO pin to go high (start of echo pulse)
while not ECHO.value():
if time.ticks_diff(time.ticks_us(), timeout_start) > 30000: # 30ms timeout
return -1 # Timeout, return -1 if no pulse is detected
time1 = time.ticks_us() # Start time for pulse width calculation
# Wait for ECHO pin to go low (end of echo pulse)
while ECHO.value():
if time.ticks_diff(time.ticks_us(), time1) > 30000: # 30ms timeout
return -1 # Timeout, return -1 if pulse is too long
time2 = time.ticks_us() # End time for pulse width calculation
# Calculate the distance based on the duration of the echo pulse
during = time.ticks_diff(time2, time1)
distance_cm = during * 340 / 2 / 10000 # Convert time to distance in cm
return distance_cm
# Function to beep the buzzer and light up the LED
def beep():
buzzer.value(1) # Turn on the buzzer
led.value(1) # Turn on the LED
time.sleep(0.1) # Beep duration
buzzer.value(0) # Turn off the buzzer
led.value(0) # Turn off the LED
time.sleep(0.1) # Short pause between beeps
# Initialize variables for controlling beep intervals
intervals = 2000 # Default long initial interval
previousMillis = time.ticks_ms() # Store the previous time to track beep intervals
# Main loop to handle distance-based beeping intervals
dis = distance() # Measure the distance directly in the main loop
# Adjust beep intervals based on the distance
if dis > 0: # Ensure valid distance is measured
if dis <= 10:
intervals = 300 # Close distance, faster beeps
elif dis <= 20:
intervals = 500 # Medium-close distance, moderate beeps
elif dis <= 50:
intervals = 1000 # Medium distance, slower beeps
intervals = 2000 # Far distance, much slower beeps
# Print the measured distance
print(f'Distance: {dis:.2f} cm')
# Check if it's time to beep again based on the interval
currentMillis = time.ticks_ms() # Get the current time
if time.ticks_diff(currentMillis, previousMillis) >= intervals:
beep() # Beep the buzzer and blink the LED
previousMillis = currentMillis # Update the time of the last beep
time.sleep_ms(100) # Small delay to avoid too frequent readings
As soon as the program runs, the ultrasonic sensor will continuously read the distance to the obstacle in front of you, and you will be able to see the exact distance value on the shell.
The LED and buzzer will change the frequency of blinking and beeping depending on the distance value, thus indicating the approach of the obstacle.
The 6.1 Measuring Distance article mentioned that when the ultrasonic sensor works, the program will be paused.
To avoid interfering with the LED or buzzer timing, we created a separate thread for ranging in this example.
