3.1 Beep
The active buzzer is a typical digital output device that is as easy to use as lighting up an LED!
ITEMS IN THIS KIT
Kepler Kit
450+
Kepler Ultimate Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico W
Micro USB Cable
Jumper Wires
Several
Transistor
1(S8050)
Resistor
1(1KΩ)
Active Buzzer
Schematic
sch_buzzer
When the GP15 output is high, after the 1K current limiting resistor (to protect the transistor), the S8050 (NPN transistor) will conduct, so that the buzzer will sound.
The role of S8050 (NPN transistor) is to amplify the current and make the buzzer sound louder. In fact, you can also connect the buzzer directly to GP15, but you will find that the buzzer sound is smaller.
Two types of buzzers are included in the kit. We need to use active buzzer. Turn them around, the sealed back (not the exposed PCB) is the one we want.
img_buzzer
The buzzer needs to use a transistor when working, here we use S8050 (NPN Transistor).
wiring_beep
  • Open the 3.1_beep.py file under the path of kepler-kit-main/micropython or copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.
  • Don’t forget to click on the “MicroPython (Raspberry Pi Pico)” interpreter in the bottom right corner.
  • For detailed tutorials, please refer to Open and Run Code Directly.
import machine
import utime
buzzer = machine.Pin(15, machine.Pin.OUT)
    for i in range(4):
        buzzer.value(1)
        utime.sleep(0.3)
        buzzer.value(0)
        utime.sleep(0.3)
    utime.sleep(1)
After the code runs, you will hear a beep every second.
