7.2 Room Temperature Meterï
Using a thermistor and an I2C LCD1602, we can create a room temperature meter.
This project is very simple, it is based on 2.13 Thermometer with I2C LCD1602 to display the temperature.
Kepler Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
1(10KΩ) |
7 |
Schematic
Open the
7.2_room_temperature_meter.pyfile under the path ofkepler-kit-main/micropythonor copy this code into Thonny, then click âRun Current Scriptâ or simply press F5 to run it.Donât forget to click on the âMicroPython (Raspberry Pi Pico)â interpreter in the bottom right corner.
For detailed tutorials, please refer to Open and Run Code Directly.
from lcd1602 import LCD
from machine import I2C, Pin
import utime
import math
# Initialize the thermistor (ADC on pin 28) and LCD display
thermistor = machine.ADC(28) # Analog input from the thermistor
# Initialize I2C communication for the LCD1602 display
# Create an LCD object for controlling the LCD1602 display
lcd = LCD(i2c)
# Main loop to continuously read temperature and display it
# Read raw ADC value from the thermistor
temperature_value = thermistor.read_u16()
# Convert the raw ADC value to a voltage (0-3.3V range)
Vr = 3.3 * float(temperature_value) / 65535 # ADC value to voltage conversion
# Calculate the thermistor resistance (using a voltage divider with a 10kOhm resistor)
Rt = 10000 * Vr / (3.3 - Vr) # Rt = thermistor resistance
# Use the Steinhart-Hart equation to calculate the temperature in Kelvin
# The values used are specific to the thermistor (3950 is the beta coefficient)
temp = 1 / (((math.log(Rt / 10000)) / 3950) + (1 / (273.15 + 25))) # Temperature in Kelvin
# Convert temperature from Kelvin to Celsius
Cel = temp - 273.15
# Display the temperature on the LCD in Celsius
string = " Temperature is \n " + str('{:.2f}'.format(Cel)) + " C" # Format string for the LCD
lcd.message(string) # Display the string on the LCD
utime.sleep(1) # Wait for 1 second
lcd.clear() # Clear the LCD for the next reading
The LCD will display the temperature value in the current environment after the program runs.
If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
