πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
74HC595
img_74hc595
The 74HC595 is an integrated circuit featuring an 8-bit shift register and a storage register with tri-state parallel outputs. It converts serial input into parallel output, allowing you to conserve MCU I/O pins.
  • When MR (pin 10) is set to high level and OE (pin 13) is set to low level, data is clocked into the shift register on the rising edge of SHcp and transferred to the storage register on the rising edge of STcp.
  • If the two clock signals are connected, the shift register will always operate one clock pulse ahead of the storage register.
  • The shift register includes a serial input pin (Ds), a serial output pin (Q7’), and an asynchronous reset (active low).
  • The storage register outputs an 8-bit parallel bus in three states.
  • When OE is enabled (low level), the data stored in the storage register is output to the parallel bus (Q0 ~ Q7).
  • 74HC595 Datasheet
img_74jc595_pin
Pins of 74HC595 and their functions:
  • Q0-Q7: 8-bit parallel data output pins, able to control 8 LEDs or 8 pins of 7-segment display directly.
  • Q7’: Series output pin, connected to DS of another 74HC595 to connect multiple 74HC595s in series
  • MR: Reset pin, active at low level;
  • SHcp: Time sequence input of shift register. On the rising edge, the data in shift register moves successively one bit, i.e. data in Q1 moves to Q2, and so forth. While on the falling edge, the data in shift register remain unchanged.
  • STcp: Time sequence input of storage register. On the rising edge, data in the shift register moves into memory register.
  • CE: Output enable pin, active at low level.
  • DS: Serial data input pin
  • VCC: Positive supply voltage.
  • GND: Ground.
Example
