Infrared Receiver
IR Receiver
img_irrecv
  • S: Signal output
  • +: VCC
  • -: GND
An infrared receiver is a component designed to receive infrared signals and output TTL-compatible signals. It resembles a standard plastic-packaged transistor in size and is ideal for various infrared remote control and transmission applications.
Infrared (IR) communication is a widely used, cost-effective, and user-friendly wireless communication technology. Infrared light, with a slightly longer wavelength than visible light, is invisible to the human eye, making it perfect for wireless communication. A common modulation method used in IR communication is 38 kHz modulation.
  • Adopted HX1838 IR Receiver Sensor, high sensitivity
  • Can be used for remote control
  • Power Supply: 3.3~5V
  • Interface: Digital
  • Modulate Frequency: 38Khz
Remote Control
img_controller
This is a Mini thin infrared wireless remote control with 21 function buttons and a transmitting distance of up to 8 meters, which is suitable for operating a wide range of devices in a kid’s room.
  • Size: 85x39x6mm
  • Remote control range: 8-10m
  • Battery: 3V button type lithium manganese battery
  • Infrared carrier frequency: 38KHz
  • Surface paste material: 0.125mm PET
  • Effective life: more than 20,000 times
Example
