7.6 Building a Traffic Light Controller
In this project, we’ll create a Traffic Light Controller using the Raspberry Pi Pico 2 W, three LEDs (red, yellow, green), and a 4-digit 7-segment display. This system will simulate a real traffic light sequence, displaying the remaining time for each light on the 7-segment display.
  • Red light: Traffic should stop if it sees a flashing red light, equivalent to a stop sign.
  • Yellow light: A warning signal is about to turn red. Yellow lights are interpreted differently in different countries (regions).
  • Green light: Allows traffic to move in the indicated direction.
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Resistor
7(220Ω)
4-Digit 7-Segment Display
74HC595
LED
Understanding the Components
  • LEDs: Represent the traffic lights. We’ll control them to simulate the standard traffic light sequence.
  • 4-Digit 7-Segment Display: Shows the countdown timer for each light.
  • 74HC595 Shift Register: Allow us to control multiple outputs (segments and digits of the display) using fewer GPIO pins on the Pico.
Schematic
sch_traffic_light
  • This circuit is based on the 5.3 Time Counter with the addition of 3 LEDs.
  • The 3 red, yellow and green LEDs are connected to GP7~GP9 respectively.
wiring_traffic_light
Writing the Code
We’ll write a MicroPython script that:
  • Controls the traffic light sequence.
  • Displays the countdown timer on the 7-segment display.
  • Uses shift registers to control the display.
  • Open the 7.6_traffic_light.py from pico-2w-kit-main/micropython or copy the code into Thonny, then click “Run” or press F5.
  • Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
from machine import Timer
# Initialize LED pins
led_pins = [7, 8, 9]  # Green, Yellow, Red LEDs connected to GP7, GP8, GP9
leds = [machine.Pin(pin, machine.Pin.OUT) for pin in led_pins]
# Define the duration for each traffic light color in seconds [Green, Yellow, Red]
light_time = [30, 5, 30]  # [Green, Yellow, Red]
# Define the binary codes for each digit (0-9)
SEGMENT_CODES = [
    0x3F,  # 0
    0x06,  # 1
    0x5B,  # 2
    0x4F,  # 3
    0x66,  # 4
    0x6D,  # 5
    0x7D,  # 6
    0x07,  # 7
    0x7F,  # 8
    0x6F   # 9
# Initialize the control pins for 74HC595
SDI = machine.Pin(18, machine.Pin.OUT)   # Serial Data Input (DS)
RCLK = machine.Pin(19, machine.Pin.OUT)  # Register Clock (STCP)
SRCLK = machine.Pin(20, machine.Pin.OUT) # Shift Register Clock (SHCP)
# Initialize digit select pins (common cathodes)
digit_pins = [
    machine.Pin(10, machine.Pin.OUT),  # Digit 1
    machine.Pin(11, machine.Pin.OUT),  # Digit 2
    machine.Pin(12, machine.Pin.OUT),  # Digit 3
    machine.Pin(13, machine.Pin.OUT)   # Digit 4
# Function to send data to 74HC595
def shift_out(data):
    RCLK.low()
    for bit in range(7, -1, -1):
        SRCLK.low()
        bit_val = (data >> bit) & 0x01
        SDI.value(bit_val)
        SRCLK.high()
    RCLK.high()
# Function to display a digit at a specific position
def display_digit(position, digit):
    # Turn off all digits
    for dp in digit_pins:
        dp.high()
    # Send segment data
    shift_out(SEGMENT_CODES[digit])
    # Activate the selected digit (common cathode is active low)
    digit_pins[position].low()
    # Small delay to allow the digit to be visible
    utime.sleep_ms(5)
    # Turn off the digit
    digit_pins[position].high()
# Function to display a number on the 4-digit display
def display_number(number):
    # Extract individual digits
    digits = [
        (number // 1000) % 10,
        (number // 100) % 10,
        (number // 10) % 10,
        number % 10
    # Display each digit rapidly
    for i in range(4):
        display_digit(i, digits[i])
# Function to update the LEDs based on the current state
def update_leds(state):
    # States: 0 = Green, 1 = Yellow, 2 = Red
    for i in range(3):
        leds[i].value(0)
    leds[state].value(1)
# Timer variables
counter = light_time[0]  # Start with green light duration
current_state = 0  # 0 = Green, 1 = Yellow, 2 = Red
# Timer interrupt callback to update the traffic light state and counter
def timer_callback(t):
    global counter, current_state
    counter -= 1
    if counter <= 0:
        current_state = (current_state + 1) % 3  # Cycle through the states
        counter = light_time[current_state]  # Reset counter for the new state
        update_leds(current_state)
# Initialize the timer
timer = Timer(period=1000, mode=Timer.PERIODIC, callback=timer_callback)
# Initial LED state
# Main loop
        display_number(counter)
    timer.deinit()
    print("Program stopped.")
When the code runs, the green LED will light up first, and the display will show a countdown from 30. After 30 seconds, the yellow LED will light up, and the display will count down from 5. Then, the red LED will light up, and the display will count down from 30. The cycle repeats indefinitely.
Understanding the Code
  1. Imports and Initialization:
    • machine: Provides access to hardware-related functions.
    • utime: Offers time-related functions.
    • Timer: Used for creating hardware timers.
  2. LED Initialization:
    Defines GPIO pins for the red, yellow, and green LEDs. Initializes each pin as an output.
  3. Traffic Light Timings:
    Specifies the duration (in seconds) for each traffic light state.
  4. Display Functions:
    • display_digit(digit): Activates a specific digit on the display.
    • shift_out(data): Sends data to the shift register.
    • display_number(num): Breaks down the number into digits and displays them using multiplexing.
  5. update_leds(state) Function:
    • Updates the LED states based on the current traffic light state.
    • Turns off all LEDs and then turns on the LED corresponding to the current state.
        for i in range(3):
            leds[i].value(0)
  6. timer_callback(t) Function:
    • Timer interrupt callback function.
    • Decrements the counter every second.
    • When the counter reaches zero, it cycles to the next traffic light state and resets the counter.
        counter -= 1
        if counter <= 0:
  7. Main Execution:
    • Initial Variables: Sets the initial state to green and initializes the counter.
    • Initialize the Timer: Creates a periodic timer that triggers every 1000 milliseconds (1 second) and calls timer_callback.
    • Set Initial LED State: Ensures the correct LED is lit at the start.
    • Main Loop: Enters an infinite loop displaying the countdown timer. Handles a keyboard interrupt (e.g., Ctrl+C) to safely deinitialize the timer and exit.
          timer.deinit()
Experimenting Further
  • Adjust Timing:
    Change the light_time list to adjust the durations for each light.
  • Add Pedestrian Crossing:
    Implement buttons and additional LEDs to simulate pedestrian crossing signals.
  • Improve Display:
    Modify the code to add features like blinking the LED when time is almost up.
  • Simulate Real Traffic Lights:
    Add more complex sequences, such as left-turn signals or multiple intersections.
Conclusion
You’ve successfully built a Traffic Light Controller using the Raspberry Pi Pico 2 W! This project demonstrates how microcontrollers can be used to control hardware components like LEDs and displays, and how timers and interrupts can create real-time applications.
Feel free to expand upon this project, adding new features or integrating it into a larger system.
