Button
img_button
Buttons are commonly used components for controlling electronic devices, typically functioning as switches to open or close circuits. While buttons come in various sizes and shapes, the one used here is a 6mm mini push-button, as shown in the images below.
In this button, pin 1 is internally connected to pin 2, and pin 3 is connected to pin 4. To complete a circuit, you only need to connect either pin 1 or pin 2 to either pin 3 or pin 4.
The following is the internal structure of a button. The symbol on the right below is usually used to represent a button in circuits.
img_button_symbol
Since the pin 1 is connected to pin 2, and pin 3 to pin 4, when the button is pressed, the 4 pins are connected, thus closing the circuit.
img_button2
Example
