DHT11 Humiture Sensor
The DHT11 digital temperature and humidity sensor is a composite sensor that provides calibrated digital output for both temperature and humidity. It combines advanced digital signal processing with reliable temperature and humidity sensing technologies to deliver high reliability and excellent long-term stability.
The sensor integrates a resistive humidity sensing component and an NTC thermistor for temperature measurement, paired with a high-performance 8-bit microcontroller for precise data processing.
Only three pins are available for use: VCC, GND, and DATA. The communication process begins with the DATA line sending start signals to DHT11, and DHT11 receives the signals and returns an answer signal. Then the host receives the answer signal and begins to receive 40-bit humiture data (8-bit humidity integer + 8-bit humidity decimal + 8-bit temperature integer + 8-bit temperature decimal + 8-bit checksum).
img_Dht11
Features
  1. Humidity measurement range: 20 - 90%RH
  2. Temperature measurement range: 0 - 60℃
  3. Output digital signals indicating temperature and humidity
  4. Working voltage:DC 5V; PCB size: 2.0 x 2.0 cm
  5. Humidity measurement accuracy: ±5%RH
  6. Temperature measurement accuracy: ±2℃
Example
