Getting to Know Pico 2 W
pico_2w_side
Raspberry Pi Pico 2 W features 2.4GHz 802.11n wireless LAN and Bluetooth 5.2, giving you even more flexibility in your IoT or smart product designs and expanding the possibilities for your projects. It is able to operate in both station andaccess-point modes. Full access to network functionality is available to both C andMicroPython developers. Raspberry Pi Pico 2 W pairs RP2350 with 4MB of flash memory, and a power supply chip supporting input voltages from 1.8–5.5V. It provides 26 GPIO pins, three of which can function as analogue inputs, on 0.1”-pitch through-hole pads with castellated edges. Raspberry Pi Pico 2 W is available as an individual unit, or in 480-unit reels for automated assembly.
Features
  • RP2350 microcontroller with 4 MB of flash memory.
  • On-board single-band 2.4GHz wireless interfaces. (802.11n, Bluetooth 5.2) - Support for Bluetooth LE Central and Peripheral roles. - Support for Bluetooth Classic.
  • Micro USB B port for power and data. (and for reprogramming the flash)
  • 40-pin 21mm×51mm ‘DIP’ style 1mm thick PCB with 0.1” through-hole pins also with edge castellations. - Exposes 26 multi-function 3.3V general purpose I/O (GPIO) - 23 GPIO are digital-only, with three also being ADC capable. - Can be surface-mounted as a module.
  • 3-pin Arm serial wire debug (SWD) port.
  • Simple yet highly flexible power supply architecture. - Various options for easily powering the unit from micro USB, external supplies or a Power Pack.
  • 1 × USB 1.1 controller and PHY, with host and device support.
  • 3 x Programmable I/O (PIO) blocks, 12 state machines in total. - Flexible, user-programmable high-speed I/O. - Can emulate interfaces such as SD card and VGA.
  • Supported input power 1.8-5.5V DC.
  • Operating temperature -20°C to +85°C.
  • Castellated module allows soldering direct to carrier boards.
  • Drag-and-drop programming using mass storage over USB.
  • Accurate on-chip clock.
  • Temperature sensor.
  • Accelerated integer and floating-point libraries on-chip.
Pico’s Pins
pico2w_pin
Function
GP0-GP28
General-purpose input/output pins
Act as either input or output and have no fixed purpose of their own
GND
0 volts ground
Several GND pins around Pico 2 W to make wiring easier.
RUN
Enables or disables your Pico
Start and stop your Pico 2 W from another microcontroller.
GPxx_ADCx
General-purpose input/output or analog input
Used as an analog input as well as a digital input or output – but not both at the same time.
ADC_VREF
Analog-to-digital converter (ADC) voltage reference
A special input pin which sets a reference voltage for any analog inputs.
AGND
Analog-to-digital converter (ADC) 0 volts ground
A special ground connection for use with the ADC_VREF pin.
3V3(O)
3.3 volts power
A source of 3.3V power, the same voltage your Pico 2 W runs at internally, generated from the VSYS input.
3v3(E)
Enables or disables the power
Switch on or off the 3V3(O) power, can also switches your Pico 2 W off.
VSYS
2-5 volts power
A pin directly connected to your Pico’s internal power supply, which cannot be switched off without also switching Pico 2 W off.
VBUS
5 volts power
A source of 5 V power taken from your Pico’s micro USB port, and used to power hardware which needs more than 3.3 V.
The best place to find everything you need to get started with your Raspberry Pi Pico 2 W is here
Or you can click on the links below:
