5.4 Displaying Graphics on an 8x8 LED Matrix
In this lesson, we’ll learn how to control an 8x8 LED matrix using the Raspberry Pi Pico 2 W and two 74HC595 shift registers. We’ll display patterns and simple graphics by controlling individual LEDs on the matrix.
PURCHASE LINK |
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
Understanding the 8x8 LED Matrix
An 8x8 LED matrix consists of 64 LEDs arranged in 8 rows and 8 columns. Each LED can be individually controlled by applying voltage across its row and column. By controlling the current through each pair of rows and columns, we can control each LED to display characters or patterns.
In this setup, we’ll use two 74HC595 shift registers to control the rows and columns of the LED matrix, effectively expanding the number of outputs from the Raspberry Pi Pico 2 while using only a few GPIO pins.
Schematic
The 8x8 LED dot matrix is controlled by two 74HC595 shift registers: one controls the rows, and the other controls the columns. These two chips share the Pico’s GPIO pins GP18, GP19, and GP20, greatly conserving the Pico’s I/O ports.
The Pico outputs a 16-bit binary number at a time. The first 8 bits are sent to the 74HC595 controlling the rows, and the last 8 bits are sent to the 74HC595 controlling the columns. This allows the dot matrix to display specific patterns.
Q7’ (Pin 9): This serial data output pin of the first 74HC595 connects to the DS (Pin 14) of the second 74HC595, enabling you to chain multiple 74HC595 chips together.
Building the circuit can be complex, so let’s proceed step by step.
Step 1: First, insert the Pico 2 W, the LED dot matrix and two 74HC595 chips into breadboard. Connect the 3.3V and GND of the Pico 2 W to holes on the two sides of the board, then hook up pin16 and 10 of the two 74HC595 chips to VCC, pin 13 and pin 8 to GND.
In the Fritzing image above, the side with label is at the bottom.
Step 2: Connect pin 11 of the two 74HC595 together, and then to GP20; then pin 12 of the two chips, and to GP19; next, pin 14 of the 74HC595 on the left side to GP18 and pin 9 to pin 14 of the second 74HC595.
Step 3: The 74HC595 on the right side is to control columns of the LED dot matrix. See the table below for the mapping. Therefore, Q0-Q7 pins of the 74HC595 are mapped with pin 13, 3, 4, 10, 6, 11, 15, and 16 respectively.
74HC595 |
Q0 |
Q1 |
Q2 |
Q3 |
Q4 |
Q5 |
Q6 |
Q7 |
LED Dot Matrix |
13 |
10 |
11 |
15 |
16 |
Step 4: Now connect the ROWs of the LED dot matrix. The 74HC595 on the left controls ROW of the LED dot matrix. See the table below for the mapping. We can see, Q0-Q7 of the 74HC595 on the left are mapped with pin 9, 14, 8, 12, 1, 7, 2, and 5 respectively.
74HC595 |
Q0 |
Q1 |
Q2 |
Q3 |
Q4 |
Q5 |
Q6 |
Q7 |
LED Dot Matrix |
9 |
14 |
8 |
12 |
7 |
Writing the Code
You can open the file
5.4_8x8_pixel_graphics.inounder the path ofpico-2w-kit-main/arduino/5.4_8x8_pixel_graphics.Or copy this code into Arduino IDE.
Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
const int STcp = 19; // Pin connected to ST_CP (latch pin) of 74HC595
const int SHcp = 20; // Pin connected to SH_CP (clock pin) of 74HC595
const int DS = 18; // Pin connected to DS (data pin) of 74HC595
// Data array representing the 'X' shape on an 8x8 LED matrix
byte datArray[] = {0x7E, 0xBD, 0xDB, 0xE7, 0xE7, 0xDB, 0xBD, 0x7E};
// Set pins as outputs
pinMode(STcp, OUTPUT);
pinMode(SHcp, OUTPUT);
pinMode(DS, OUTPUT);
void loop()
for(int num = 0; num <8; num++)
digitalWrite(STcp,LOW); //ground ST_CP and hold low for as long as you are transmitting
shiftOut(DS,SHcp,MSBFIRST,datArray[num]);
shiftOut(DS,SHcp,MSBFIRST,0x80>>num);
//return the latch pin high to signal chip that it
//no longer needs to listen for information
digitalWrite(STcp,HIGH); //pull the ST_CPST_CP to save the data
After uploading the code, the LED matrix should display an ‘X’ pattern by lighting up the appropriate LEDs. If the pattern is not visible, try adjusting the timing or check the wiring connections.
Understanding the Code
Pin Definitions:
STcp (ST_CP): Used to latch the shifted data into the output register on a rising edge.SHcp (SH_CP): Shifts data into the register on each rising edge.DS: Serial data input for the shift register.
const int STcp = 19; // Latch pin (ST_CP) of 74HC595 const int SHcp = 20; // Clock pin (SH_CP) of 74HC595 const int DS = 18; // Data pin (DS) of 74HC595
Data Array (
datArray):Each element represents a row in the LED matrix.
The hex values correspond to the LEDs that should be lit (0) or off (1) in each row.
This pattern forms a symmetrical ‘X’ shape across the matrix.
Setup Function:
Initializes the control pins as outputs to communicate with the shift registers.
void setup() { // Set pins as outputs pinMode(STcp, OUTPUT); pinMode(SHcp, OUTPUT); pinMode(DS, OUTPUT); }
Loop Function:
numranges from 0 to 7, representing each row of the LED matrix.0x80>>numactivates one row at a time.shiftOut()sends the column and row data to the shift registers, starting with the most significant bit (MSBFIRST).Latches the data to the output pins by toggling the
STcp.
void loop() { for(int num = 0; num <8; num++) { digitalWrite(STcp,LOW); //ground ST_CP and hold low for as long as you are transmitting shiftOut(DS,SHcp,MSBFIRST,datArray[num]); shiftOut(DS,SHcp,MSBFIRST,0x80>>num); //return the latch pin high to signal chip that it //no longer needs to listen for information digitalWrite(STcp,HIGH); //pull the ST_CPST_CP to save the data } }
Troubleshooting
No Dots Lighting Up:
Verify all power connections.
Ensure that the shift registers are properly connected to the Pico.
Incorrect Patterns:
Double-check the pattern array.
Ensure that the rows and columns are correctly wired to the shift registers.
Flickering or Unstable Display:
Adjust the delay value in the loop to find a balance between performance and visual stability.
Ensure that power supply is stable and sufficient for the number of LEDs being used.
Experimenting Further
Changing the Pattern
Try replacing the pattern list with the following arrays to display different graphics. Replace pattern in your code with
pattern_heartorpattern_smileto see different images.// Heart shape pattern byte pattern_heart[] = { 0xFF, // 11111111 0x99, // 10011001 0x00, // 00000000 0x00, // 00000000 0x00, // 00000000 0x81, // 10000001 0xC3, // 11000011 0xE7 // 11100111 }; // Smile face pattern byte pattern_smile[] = { 0xC3, // 11000011 0xBD, // 10111101 0x5A, // 01011010 0x7E, // 01111110 0x5A, // 01011010 0x66, // 01100110 0xBD, // 10111101 0xC3 // 11000011 };
Animating the Display
Create multiple patterns and cycle through them to create animations:
const int STcp = 19; // Pin connected to ST_CP (latch pin) of 74HC595 const int SHcp = 20; // Pin connected to SH_CP (clock pin) of 74HC595 const int DS = 18; // Pin connected to DS (data pin) of 74HC595 // Heart shape pattern byte pattern_heart[] = { 0xFF, 0x99, 0x00, 0x00, 0x00, 0x81, 0xC3, 0xE7 }; // Smile face pattern byte pattern_smile[] = { 0xC3, 0xBD, 0x5A, 0x7E, 0x5A, 0x66, 0xBD, 0xC3 }; void setup() { // Set pins as outputs pinMode(STcp, OUTPUT); pinMode(SHcp, OUTPUT); pinMode(DS, OUTPUT); } void latchData() { // Latch the shifted data to the output pins of the 74HC595 digitalWrite(STcp, HIGH); // Latch data digitalWrite(STcp, LOW); // Prepare for the next data transmission } void displayPattern(byte pattern[]) { for (int repeat = 0; repeat < 500; repeat++) { // Display the pattern for a certain duration for (int row = 0; row < 8; row++) { // Begin data transmission digitalWrite(STcp, LOW); // Prepare to shift data // Shift out column data (pattern for the current row) shiftOut(DS, SHcp, MSBFIRST, pattern[row]); // Shift out row data (activating one row at a time) shiftOut(DS, SHcp, MSBFIRST, 1 << row); // Latch the data to display latchData(); // Short delay for persistence of vision delay(1); } } } void loop() { // Continuously display patterns: heart and smiley face displayPattern(pattern_heart); // Display the heart shape displayPattern(pattern_smile); // Display the smiley face }
Conclusion
In this lesson, you’ve learned how to control an 8x8 LED matrix using the Raspberry Pi Pico and two 74HC595 shift registers. By leveraging shift registers, you can efficiently manage multiple LEDs with minimal GPIO usage, allowing for more complex and interactive projects. Understanding how to send serial data and latch it into parallel outputs enables you to create dynamic patterns and graphics on the LED matrix.
