5.3 Time Counter
In this lesson, we’ll learn how to use a 4-digit 7-segment display with the Raspberry Pi Pico 2 W to create a simple time counter. The display will count up every second, showing the elapsed time in seconds.
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Resistor
4(220Ω)
4-Digit 7-Segment Display
74HC595
Understanding the 4-Digit 7-Segment Display
A 4-digit 7-segment display consists of four individual 7-segment displays combined into a single module. Each digit shares the same segment control lines (a to g and dp), but each digit has its own common cathode control. This configuration allows us to control which digit is active at any given time.
To display different numbers on each digit using shared segment lines, we use a technique called multiplexing. We rapidly switch between digits, updating one digit at a time, but so quickly that it appears as if all digits are displayed simultaneously due to the persistence of vision.
4digit_control_pins
Schematic
sch_4dig
Here the wiring principle is basically the same as 5.1 Using the 74HC595 Shift Register, the only difference is that Q0-Q7 are connected to the a ~ g pins of the 4-digit 7-segment display.
Then G10 ~ G13 will select which 7-segment display to work.
wiring_4dig
  • Segment Connections (through 220 Ω resistors):
    • Q0 → Segment a
    • Q1 → Segment b
    • Q2 → Segment c
    • Q3 → Segment d
    • Q4 → Segment e
    • Q5 → Segment f
    • Q6 → Segment g
    • Q7 → Segment dp (decimal point)
  • Common Cathode Connections (Digit Select Pins):
    • Digit 1 (Leftmost Digit): Connect to GP10 on the Pico
    • Digit 2: Connect to GP11
    • Digit 3: Connect to GP12
    • Digit 4 (Rightmost Digit): Connect to GP13
Writing the Code
Let’s write a MicroPython program to create a time counter that increments every second and displays the count on the 4-digit 7-segment display.
  • Open the 5.3_time_counter.py from pico-2w-kit-main/micropython or copy the code into Thonny, then click “Run” or press F5.
  • Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Define the binary codes for each digit (0-9)
SEGMENT_CODES = [
    0x3F,  # 0
    0x06,  # 1
    0x5B,  # 2
    0x4F,  # 3
    0x66,  # 4
    0x6D,  # 5
    0x7D,  # 6
    0x07,  # 7
    0x7F,  # 8
    0x6F   # 9
# Initialize the control pins for 74HC595
SDI = machine.Pin(18, machine.Pin.OUT)   # Serial Data Input (DS)
RCLK = machine.Pin(19, machine.Pin.OUT)  # Register Clock (STCP)
SRCLK = machine.Pin(20, machine.Pin.OUT) # Shift Register Clock (SHCP)
# Initialize digit select pins (common cathodes)
digit_pins = [
    machine.Pin(10, machine.Pin.OUT),  # Digit 1
    machine.Pin(11, machine.Pin.OUT),  # Digit 2
    machine.Pin(12, machine.Pin.OUT),  # Digit 3
    machine.Pin(13, machine.Pin.OUT)   # Digit 4
# Function to send data to 74HC595
def shift_out(data):
    RCLK.low()
    for bit in range(7, -1, -1):
        SRCLK.low()
        bit_val = (data >> bit) & 0x01
        SDI.value(bit_val)
        SRCLK.high()
    RCLK.high()
# Function to display a digit at a specific position
def display_digit(position, digit):
    # Turn off all digits
    for dp in digit_pins:
        dp.high()
    # Send segment data
    shift_out(SEGMENT_CODES[digit])
    # Activate the selected digit (common cathode is active low)
    digit_pins[position].low()
    # Small delay to allow the digit to be visible
    utime.sleep_ms(5)
    # Turn off the digit
    digit_pins[position].high()
# Function to display a number on the 4-digit display
def display_number(number):
    # Extract individual digits
    digits = [
        (number // 1000) % 10,
        (number // 100) % 10,
        (number // 10) % 10,
        number % 10
    # Display each digit rapidly
    for i in range(4):
        display_digit(i, digits[i])
# Main loop
counter = 0
last_update = utime.ticks_ms()
    # Update the counter every 1000 ms (1 second)
    current_time = utime.ticks_ms()
    if utime.ticks_diff(current_time, last_update) >= 1000:
        counter += 1
        if counter > 9999:
            counter = 0
        last_update = current_time
    # Continuously refresh the display
    display_number(counter)
When you run this code, the 4-digit 7-segment display will function as a counter, incrementing the displayed number by 1 every second, starting from 0 up to 9999, then resetting to 0 and repeating the cycle continuously.
Understanding the Code
  1. Import Modules:
    • machine: Provides access to GPIO pins and hardware functions.
    • utime: Contains time-related functions for delays and timing.
  2. Define Segment Codes:
    Each entry corresponds to the segments that need to be lit to display a digit. The values are in hexadecimal format.
    SEGMENT_CODES = [
        0x3F,  # 0
        0x06,  # 1
        0x5B,  # 2
        0x4F,  # 3
        0x66,  # 4
        0x6D,  # 5
        0x7D,  # 6
        0x07,  # 7
        0x7F,  # 8
        0x6F   # 9
  3. Initialize Control Pins:
    Assigns the Pico’s GPIO pins to control the 74HC595.
  4. Initialize Digit Select Pins:
    Controls which digit is active. Active low (common cathode).
    digit_pins = [
  5. Define the shift_out Function:
    • Sends 8 bits of data to the 74HC595.
    • Shifts out the data starting from the most significant bit (MSB).
    • Pulses the shift and register clocks appropriately.
        RCLK.low()
            SRCLK.low()
            SDI.value(bit_val)
            SRCLK.high()
        RCLK.high()
  6. Define the display_digit Function:
    • Turns off all digits.
    • Sends the segment code for the digit.
    • Activates the specified digit by setting its pin low.
    • Adds a small delay to make the digit visible.
    • Turns off the digit after displaying.
            dp.high()
        utime.sleep_ms(5)
  7. Define the display_number Function:
    • Extracts each digit from the number.
    • Calls display_digit for each digit rapidly to create the multiplexing effect.
        digits = [
            number % 10
        for i in range(4):
  8. Main Loop:
    • Increments the counter every second.
    • Resets the counter after reaching 9999.
    • Continuously calls display_number to refresh the display.
    counter = 0
            counter += 1
            if counter > 9999:
                counter = 0
Experimenting Further
  • Add a Reset Button:
    Connect a button to the Pico to reset the counter when pressed.
  • Display Different Data:
    Modify the code to display sensor readings, such as temperature or light levels.
  • Adjust Display Brightness:
    Change the utime.sleep_ms(5) delay in the display_digit function to adjust how long each digit is displayed, affecting brightness.
  • Create a Stopwatch:
    Implement start, stop, and reset functionality to use the display as a stopwatch.
Conclusion
In this lesson, you’ve learned how to use a 4-digit 7-segment display with a 74HC595 shift register to create a time counter using the Raspberry Pi Pico 2 W. By understanding multiplexing and efficient timing, you can display dynamic information on multi-digit displays using minimal GPIO pins.
