Water Level Sensor Module
img_water_sensor
The water level sensor detects the water level and transmits the signal to a controller. The controller’s computer compares the measured water level with the preset value to calculate the deviation. Based on this deviation, it sends “on” or “off” commands to the feedwater valve, ensuring the water level in the vessel reaches the desired setting.
Design and Functionality The sensor features ten exposed copper traces: five power traces and five sensor traces arranged in an interleaved pattern. When submerged in water, the traces are bridged, allowing current to flow. The circuit board also includes a power indicator LED, which lights up when the sensor is powered.
The traces function as a variable resistor, with resistance changing based on water immersion:
  • More Water: Increased conductivity lowers the resistance.
  • Less Water: Reduced conductivity raises the resistance.
The sensor processes this varying resistance into an output voltage signal, which is sent to a microcontroller. The microcontroller uses this signal to determine the water level accurately.
Warning
The sensor cannot be fully submerged in water, please only leave the part where the ten traces are located in contact with water. In addition, energizing the sensor in a humid environment will speed up the corrosion of the probe and cut the life of the sensor, so we recommend that you only supply power when taking readings.
Example
