5.4 8x8 Pixel Graphics
In this lesson, we’ll learn how to control an 8x8 LED matrix using the Raspberry Pi Pico 2 W and two 74HC595 shift registers. We’ll display patterns and simple graphics by controlling individual LEDs on the matrix.
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Understanding the 8x8 LED Matrix
The 8x8 LED dot matrix is controlled by two 74HC595 shift registers: one controls the rows, and the other controls the columns. These two chips share the Pico’s GPIO pins GP18, GP19, and GP20, greatly conserving the Pico’s I/O ports.
The Pico outputs a 16-bit binary number at a time. The first 8 bits are sent to the 74HC595 controlling the rows, and the last 8 bits are sent to the 74HC595 controlling the columns. This allows the dot matrix to display specific patterns.
Q7’ (Pin 9): This serial data output pin of the first 74HC595 connects to the DS (Pin 14) of the second 74HC595, enabling you to chain multiple 74HC595 chips together.
Schematic
The 8x8 dot matrix is controlled by two 74HC595 chips, one controlling the rows and one controlling the columns, while these two chips share G18~G20, which can greatly save the I/O ports of the Pico 2 W board.
Pico 2 W needs to output a 16-bit binary number at a time, the first 8 bits are given to the 74HC595 which controls the rows, and the last 8 bits are given to the 75HC595 which controls the columns, so that the dot matrix can display a specific pattern.
Q7’: Series output pin, connected to DS of another 74HC595 to connect multiple 74HC595s in series.
Building the circuit can be complex, so let’s proceed step by step.
Step 1: First, insert the Pico 2 W, the LED dot matrix and two 74HC595 chips into breadboard. Connect the 3.3V and GND of the Pico 2 W to holes on the two sides of the board, then hook up pin16 and 10 of the two 74HC595 chips to VCC, pin 13 and pin 8 to GND.
In the Fritzing image above, the side with label is at the bottom.
Step 2: Connect pin 11 of the two 74HC595 together, and then to GP20; then pin 12 of the two chips, and to GP19; next, pin 14 of the 74HC595 on the left side to GP18 and pin 9 to pin 14 of the second 74HC595.
Step 3: The 74HC595 on the right side is to control columns of the LED dot matrix. See the table below for the mapping. Therefore, Q0-Q7 pins of the 74HC595 are mapped with pin 13, 3, 4, 10, 6, 11, 15, and 16 respectively.
74HC595 |
Q0 |
Q1 |
Q2 |
Q3 |
Q4 |
Q5 |
Q6 |
Q7 |
LED Dot Matrix |
13 |
10 |
11 |
15 |
16 |
Step 4: Now connect the ROWs of the LED dot matrix. The 74HC595 on the left controls ROW of the LED dot matrix. See the table below for the mapping. We can see, Q0-Q7 of the 74HC595 on the left are mapped with pin 9, 14, 8, 12, 1, 7, 2, and 5 respectively.
74HC595 |
Q0 |
Q1 |
Q2 |
Q3 |
Q4 |
Q5 |
Q6 |
Q7 |
LED Dot Matrix |
9 |
14 |
8 |
12 |
7 |
Writing the Code
We’ll write a MicroPython program to display a pattern on the LED matrix.
Open the
5.4_8x8_pixel_graphics.pyfrompico-2w-kit-main/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
# Define the pins connected to the 74HC595 shift register
sdi = machine.Pin(18, machine.Pin.OUT) # Serial Data Input
rclk = machine.Pin(19, machine.Pin.OUT) # Storage Register Clock (RCLK)
srclk = machine.Pin(20, machine.Pin.OUT) # Shift Register Clock (SRCLK)
# Define the glyph data for the letter 'X' with lit pixels and background off
glyph = [0x7E, 0xBD, 0xDB, 0xE7, 0xE7, 0xDB, 0xBD, 0x7E]
def hc595_in(dat):
Shifts 8 bits of data into the 74HC595 shift register.
for bit in range(7, -1, -1):
srclk.low()
sdi.value((dat >> bit) & 1) # Output data bit by bit
srclk.high()
time.sleep_us(1) # Short delay to ensure proper timing
def hc595_out():
Latches the data from the shift register to the storage register,
updating the outputs.
rclk.high()
rclk.low()
for i in range(8):
hc595_in(glyph[i]) # Send the column data for the current row
hc595_in(1 << i) # Activate the current row
hc595_out() # Update the display
time.sleep_ms(1) # Delay for visual persistence
When you run this code, the 8x8 LED matrix will display an ‘X’ shape, with the LEDs lighting up to form the pattern of the letter ‘X’ across the matrix.
Understanding the Code
Importing Modules:
machine: Provides access to hardware-related functions, such as controlling GPIO pins.time: Used for adding delays to control timing.
Defining Pins:
sdi: Sends serial data into the shift register.rclk: Latches the shifted data to the output pins.srclk: Shifts the data into the register on each rising edge.
Defining the Glyph for ‘X’:
Each element represents a row in the LED matrix.
The hex values correspond to the LEDs that should be lit (0) or off (1) in each row.
This pattern forms a symmetrical ‘X’ shape across the matrix.
Function
hc595_in(dat):This function sends 8 bits of data (
dat) into the shift register serially.It iterates from the most significant bit to the least significant bit.
The
srclkpin is toggled to shift each bit into the register.The
sdipin sets the data line high or low depending on the current bit.
def hc595_in(dat): """ Shifts 8 bits of data into the 74HC595 shift register. """ for bit in range(7, -1, -1): srclk.low() sdi.value((dat >> bit) & 1) # Output data bit by bit srclk.high() time.sleep_us(1) # Short delay to ensure proper timing
Function
hc595_out():This function latches the shifted data from the shift register to the output register.
A rising edge on the
rclkpin transfers the data to the output pins, updating the LEDs.
def hc595_out(): rclk.high() rclk.low()
Main Loop:
The loop continuously refreshes the display to create a persistent image of the letter ‘X’.
The
forloop iterates over each row index from 0 to 7.hc595_in(1 << i)activates one row at a time by setting a single bit high.hc595_in(glyph[i])sends the column data for the current row, determining which LEDs in that row should be lit.hc595_out()latches the data, updating the LED matrix display.time.sleep_ms(1)provides a short delay to ensure that each row is displayed long enough to be perceived by the human eye.This rapid scanning creates the illusion of the entire ‘X’ being displayed simultaneously.
while True: for i in range(8): hc595_in(glyph[i]) # Send the column data for the current row hc595_in(1 << i) # Activate the current row hc595_out() # Update the display time.sleep_ms(1) # Delay for visual persistence
Experimenting Further
Changing the Pattern
Try replacing the pattern list with the following arrays to display different graphics. Replace pattern in your code with
pattern_heartorpattern_smileto see different images.# Heart shape pattern_heart = [ 0b11111111, 0b10011001, 0b00000000, 0b00000000, 0b00000000, 0b10000001, 0b11000011, 0b11100111 ] # Smile face pattern_smile = [ 0b11000011, # Row 0 0b10111101, # Row 1 0b01011010, # Row 2 0b01111110, # Row 3 0b01011010, # Row 4 0b01100110, # Row 5 0b10111101, # Row 6 0b11000011 # Row 7 ]
Animating the Display
Create multiple patterns and cycle through them to create animations:
import machine import time # Define pins connected to the 74HC595 shift registers sdi = machine.Pin(18, machine.Pin.OUT) # Serial Data Input rclk = machine.Pin(19, machine.Pin.OUT) # Register Clock (Latch) srclk = machine.Pin(20, machine.Pin.OUT) # Shift Register Clock # Heart shape pattern_heart = [ 0b11111111, 0b10011001, 0b00000000, 0b00000000, 0b00000000, 0b10000001, 0b11000011, 0b11100111 ] # Smile face pattern_smile = [ 0b11000011, # Row 0 0b10111101, # Row 1 0b01011010, # Row 2 0b01111110, # Row 3 0b01011010, # Row 4 0b01100110, # Row 5 0b10111101, # Row 6 0b11000011 # Row 7 ] def hc595_in(dat): """ Shift 8 bits of data into the 74HC595 shift register. """ for bit in range(7, -1, -1): srclk.low() # Prepare to shift data sdi.value((dat >> bit) & 1) # Set data bit srclk.high() # Shift data bit into register time.sleep_us(1) # Short delay for timing def hc595_out(): """ Latch the shifted data to the output pins of the 74HC595. """ rclk.high() # Latch data (rising edge) rclk.low() # Prepare for next data def display_pattern(pattern): """ Display a given 8x8 pattern on the LED matrix. """ for _ in range(500): # Display the pattern for a certain duration for i in range(8): hc595_in(pattern[i]) # Send column data for current row hc595_in(1 << i) # Activate current row hc595_out() # Update the output time.sleep_ms(1) # Short delay for persistence while True: display_pattern(pattern_heart) # Display the heart shape display_pattern(pattern_smile) # Display the smiley face
Design Your Own Patterns
Each byte represents a row; bits set to 0 turn on the LED in that column. Create custom patterns by defining your own pattern list.
Conclusion
In this lesson, you’ve learned how to control an 8x8 LED matrix using the Raspberry Pi Pico 2 W and two 74HC595 shift registers. By understanding how to manipulate bits and use shift registers, you can display patterns and graphics on the LED matrix.
