Potentiometer
img_pot
A potentiometer is a variable resistor with three terminals, allowing its resistance value to be adjusted according to a specific pattern or mechanism.
Potentiometers come in various shapes, sizes, and resistance values, but they share these common characteristics:
  • They have three terminals (or connection points).
  • They have a knob, screw, or slider that can be moved to vary the resistance between the middle terminal and either one of the outer terminals.
  • The resistance between the middle terminal and either one of the outer terminals varies from 0 Ω to the maximum resistance of the pot as the knob, screw, or slider is moved.
Here is the circuit symbol of potentiometer.
img_pot_symbol
The functions of the potentiometer in the circuit are as follows:
  1. Serving as a voltage divider
    Potentiometer is a continuously adjustable resistor. When you adjust the shaft or sliding handle of the potentiometer, the movable contact will slide on the resistor. At this point, a voltage can be output depending on the voltage applied onto the potentiometer and the angle the movable arm has rotated to or the travel it has made.
  2. Serving as a rheostat
    When the potentiometer is used as a rheostat, connect the middle pin and one of the other 2 pins in the circuit. Thus you can get a smoothly and continuously changed resistance value within the travel of the moving contact.
  3. Serving as a current controller
    When the potentiometer acts as a current controller, the sliding contact terminal must be connected as one of the output terminals.
If you want to know more about potentiometer, refer to: Potentiometer - Wikipedia
Example
