DC Motor
img_dc_motor
This is a 3V DC motor. It operates when a high voltage level is applied to one terminal and a low voltage level to the other, causing the motor to rotate.
  • Size: 25*20*15MM
  • Operation Voltage: 1-6V
  • Free-run Current (3V): 70m
  • A Free-run Speed (3V): 13000RPM
  • Stall Current (3V): 800mA
  • Shaft Diameter: 2mm
Direct current (DC) motor is a continuous actuator that converts electrical energy into mechanical energy. DC motors make rotary pumps, fans, compressors, impellers, and other devices work by producing continuous angular rotation.
A DC motor consists of two parts, the fixed part of the motor called the stator and the internal part of the motor called the rotor (or armature of a DC motor) that rotates to produce motion. The key to generating motion is to position the armature within the magnetic field of the permanent magnet (whose field extends from the north pole to the south pole). The interaction of the magnetic field and the moving charged particles (the current-carrying wire generates the magnetic field) produces the torque that rotates the armature.
img_dc_motor_sche
Current flows from the positive terminal of the Power Pack through the circuit, through the copper brushes to the commutator, and then to the armature. But because of the two gaps in the commutator, this flow reverses halfway through each complete rotation. This continuous reversal essentially converts the DC power from the Power Pack to AC, allowing the armature to experience torque in the right direction at the right time to maintain rotation.
Example
