3.5 - Small Fan
Now we use the TA6586 to drive the DC motor to make it rotate clockwise and counterclockwise. Since the DC motor requires a relatively large current, for safety reasons, here we use a power module to supply power to the motor.
ITEMS IN THIS KIT
PURCHASE LINK
Kepler Kit
450+
Kepler Ultimate Kit
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Getting to Know Pico W
Micro USB Cable
Jumper Wires
Several
TA6586 - Motor Driver Chip
DC Motor
Li-po Charger Module
Power Pack
Battery Holder
Schematic
sch_motor
  • Since DC motors require a high current, we use a Li-po Charger module to power the motor here for safety reasons.
  • Make sure your Li-po Charger Module is connected as shown in the diagram. Otherwise, a short circuit will likely damage your battery and circuitry.
wiring_motor
  • You can open the file 3.5_small_fan.ino under the path of kepler-kit-main/arduino/3.5_small_fan.
  • Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
Once the program is running, the motor will rotate back and forth in a regular pattern.
  • If you can not upload the code again, this time you need to connect the RUN pin on the Pico W with a wire to GND to reset it, and then unplug this wire to run the code again.
  • This is because the motor is operating with too much current, which may cause the Pico W to disconnect from the computer.
wiring_run_reset
