2.8 - Press Gently
img_micro_switch
Micro Switch is also a 3-pin device, the sequence of the 3 pins are C (common pin), NO (normally open) and NC (normally closed) .
When the micro switch is not pressed, 1 (C) and 3 (NC) are connected together, when pressed 1 (C) and 2 (NO) are connected together.
ITEMS IN THIS KIT
PURCHASE LINK
Kepler Kit
450+
Kepler Ultimate Kit
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Getting to Know Pico W
Micro USB Cable
Jumper Wires
Several
Resistor
1(10KΩ)
Capacitor
1(104)
Micro Switch
Schematic
sch_limit_sw
By default, GP14 is low and when pressed, GP14 is high.
The purpose of the 10K resistor is to keep the GP14 low during pressing.
The 104 ceramic capacitor is used here to eliminate jitter.
wiring_limit_sw
  • You can open the file 2.8_press_gently.ino under the path of kepler-kit-main/arduino/2.8_press_gently.
  • Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
After the program runs, when you toggle the slide switch to the right, “The switch works!” will appear in the Serial Monitor.
