5.3 - Time Counterο
4-Digit 7-segment display consists of four 7- segment displays working together.
The 4-digtal 7-segment display works independently. It uses the principle of human visual persistence to quickly display the characters of each 7-segment in a loop to form continuous strings.
For example, when β1234β is displayed on the display, β1β is displayed on the first 7-segment, and β234β is not displayed. After a period of time, the second 7-segment shows β2β, the 1st 3th 4th of 7-segment does not show, and so on, the four digital display show in turn. This process is very short (typically 5ms), and because of the optical afterglow effect and the principle of visual residue, we can see four characters at the same time.
PURCHASE LINK |
Kepler Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
4(220Ξ©) |
7 |
Schematic
Here the wiring principle is basically the same as 5.1 - Microchip - 74HC595, the only difference is that Q0-Q7 are connected to the a ~ g pins of the 4-digit 7-segment display.
Then G10 ~ G13 will select which 7-segment display to work.
You can open the file
5.3_time_counter.inounder the path ofkepler-kit-main/arduino/5.3_time_counter.Or copy this code into Arduino IDE.
Donβt forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
After the program is run, you will see the 4-digit 7-segment display become a counter and the number increases by 1 per second.
How it works?
Writing signals to each 7-segment display is done in the same way as 5.2 - Number Display, using the hc595_shift() function.
The core point of the 4-digit 7-segment display is to selectively activate each 7-segment display. The code associated with this is as follows.
const int placePin[4] = {13,12,11,10};
void setup ()
for (int i = 0; i<4;i++){
pinMode(placePin[i],OUTPUT);
void loop()
pickDigit(0);
hc595_shift(count%10/1);
pickDigit(1);
hc595_shift(count%100/10);
pickDigit(2);
hc595_shift(count%1000/100);
pickDigit(3);
hc595_shift(count%10000/1000);
void pickDigit(int digit){
for(int i = 0; i < 4; i++){
digitalWrite(placePin[i],HIGH);
digitalWrite(placePin[digit],LOW);
Here, four pins (GP10, GP11, GP12, GP13) are used to control each bit of the 4-digit 7-segment display individually.
When the status of these pins is LOW, the corresponding 7-segment display is active; when the status is HIGH, the 7-segment display does not work.
Here the pickDigit(digit) function is used to unable all 7-segment displays and then enable a particular digit individually.
After that, hc595_shift() is used to write the corresponding 8 bits code for the 7-segment display.
The 4-digit 7-segment display needs to be continuously activated in turn so that we can see it display four digits, which means that the main program cannot easily add code that would affect the timing.
However, we need to add a timing function to this example, if we add a delay (1000), we will be able to detect the illusion of its four 7-segment displays working at the same time, exposing the fact that only one 7-segment display at a time to light.
Then, using the millis() function is an excellent way to do this.
void setup ()
timerStart = millis();
void loop()
unsigned int count = (millis()-timerStart)/1000;
The millis() function gets the number of milliseconds that have passed since the current program was started. We record the first time value as timerStart;
then when we need to get the time again, we call the millis() function again and subtract timerStart from the value to get how long the program has been running.
Finally, convert this time value and let the 4-digit 7-segment display to display it.
