2.15 - Two Kinds of Transistors
This kit is equipped with two types of transistors, S8550 and S8050, the former is PNP and the latter is NPN. They look very similar, and we need to check carefully to see their labels. When a High level signal goes through an NPN transistor, it is energized. But a PNP one needs a Low level signal to manage it. Both types of transistor are frequently used for contactless switches, just like in this experiment.
Let’s use LED and button to understand how to use transistor!
PURCHASE LINK |
Kepler Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
3(220Ω, 1KΩ, 10KΩ) |
7 |
8 |
1(S8050/S8550) |
Way to connect NPN (S8050) transistor
In this circuit, when the button is pressed, GP14 is high.
By programming GP15 to output high, after a 1k current limiting resistor (to protect the transistor), the S8050 (NPN transistor) is allowed to conduct, thus allowing the LED to light up.
Way to connect PNP(S8550) transistor
In this circuit, GP14 is low by the default and will change to high when the button is pressed.
By programming GP15 to output low, after a 1k current limiting resistor (to protect the transistor), the S8550 (PNP transistor) is allowed to conduct, thus allowing the LED to light up.
The only difference you will notice between this circuit and the previous one is that in the previous circuit the cathode of the LED is connected to the collector of the S8050 (NPN transistor), while this one is connected to the emitter of the S8550 (PNP transistor).
You can open the file
2.15_transistor.inounder the path ofkepler-kit-main/arduino/2.15_transistor.Or copy this code into Arduino IDE.
Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
Two kinds of transistors can be controlled with the same code. When we press the button, Pico W will send a high-level signal to the transistor; when we release it, it will send a low-level signal. We can see that diametrically opposite phenomena have occurred in the two circuits.
The circuit using the S8050 (NPN transistor) will light up when the button is pressed, which means it is receiving a high-level conduction circuit;
The circuit that uses the S8550 (PNP transistor) will light up when it is released, which means it is receiving a low-level conduction circuit.
