3.1.3 Audio Module
In this project, let’s make a DIY stereo with an audio power amplifier module, 8ohm/2w speakers and a 3.5mm Audio cable.
../_images/audio2.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Audio Module and Speaker
Experimental Procedures
Step 1: Build the circuit.
../_images/4.1.4fritzing1.png
After building the circuit according to the above diagram, then plug the audio cable into the Raspberry Pi’s 3.5mm audio jack.
../_images/audio41.png
Step 2: Get into the folder of the code.
cd ~/raphael-kit/python/
Step 3: Run.
python3 3.1.3_AudioModule.py
After the code runs, you can enjoy the music.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
from pygame import mixer
import os
user = os.getlogin()
user_home = os.path.expanduser(f'~{user}')
mixer.init()
def main():
    mixer.music.load(f'{user_home}/raphael-kit/music/my_music.mp3')
    mixer.music.set_volume(0.7)
    mixer.music.play()
        pass# Don't do anything.
def destroy():
    mixer.music.stop()
if __name__ == '__main__':
        main()
        destroy()
Code Explanation
mixer.init()
Import the mixer method in the pygame library and initialize the method.
mixer.music.play()
This code reads the my_music.mp3 file in the ~/raphael-kit/music directory and sets the volume to 0.7(The range is 0~1). The Raspberry Pi will start playing audio When mixer.music.play() is called.
You can also upload other music files to your Raspberry Pi. For a detailed tutorial, please refer to: FileZilla Software
mixer.music.stop()
Calling mixer.music.stop() will stop playing audio. In addition, you can also pause with mixer.music.pause() and continue with mixer.music.unpause().
Phenomenon Picture
../_images/3.1.3audio.JPG
