3.1.1 Photograph Module
In this kit, equipped with a camera module, let’s try to take a picture with Raspberry Pi.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Experimental Procedures
Step 1: Go into the Raspberry Pi Desktop. You may need a screen for a better experience, refer to: Connect your Raspberry Pi. Or access the Raspberry Pi desktop remotely, for a detailed tutorial please refer to Remote Desktop.
Step 2: Open a Terminal and get into the folder of the code.
cd ~/raphael-kit/python/
Step 3: Run.
sudo python3 3.1.1_PhotographModule.py
After the code runs, the camera will take a photo. Now you can see the photo named my_photo.jpg in the ~ directory.
You can also open 3.1.1_PhotographModule.py in the ~/raphael-kit/python/ path with a Python IDE, click Run button to run, and stop the code with Stop button.
If you want to download the photo to your PC, please refer to FileZilla Software.
import os
# Get the current user's login name
user = os.getlogin()
# Get the path to the user's home directory
user_home = os.path.expanduser(f'~{user}')
# Create a Picamera2 instance
camera = Picamera2()
# Retrieve the default preview configuration
preview_config = camera.preview_configuration
# Set preview size and format
preview_config.size = (800, 600)
preview_config.format = 'XRGB8888'
# Start the camera preview in QTGL mode
camera.start_preview(Preview.QTGL)
# Start the camera
camera.start()
# Capture and save a photo to the user's home directory
camera.capture_file(f'{user_home}/my_photo.jpg')
# Stop the camera preview if a KeyboardInterrupt (e.g., Ctrl+C) occurs
camera.stop_preview()
Code Explanation
Imports the
Picamera2andPreviewclasses from the picamera2 library, and theosmodule for operating system interactions.#!/usr/bin/env python3 from picamera2 import Picamera2, Preview import os
Retrieves the current user’s login name and the path to their home directory.
# Get the current user's login name user = os.getlogin() # Get the path to the user's home directory user_home = os.path.expanduser(f'~{user}')
Creates an instance of the
Picamera2class and retrieves the default preview configuration.# Create a Picamera2 instance camera = Picamera2() # Retrieve the default preview configuration preview_config = camera.preview_configuration
Sets the size and format of the camera preview. The size is set to 800x600 pixels, and the format is set to
XRGB8888.try: # Set preview size and format preview_config.size = (800, 600) preview_config.format = 'XRGB8888' ...
Starts the camera preview in QTGL mode, which is a method for displaying the preview, and then starts the camera itself.
try: ... # Start the camera preview in QTGL mode camera.start_preview(Preview.QTGL) # Start the camera camera.start() ...
Capture an image from the camera, storing it in
~/.try: ... # Capture and save a photo to the user's home directory camera.capture_file(f'{user_home}/my_photo.jpg')
You can use
camera.capture()function andforloop together to achieve continuous shooting. And use thedelayfunction to adjust the time interval for taking pictures.for i in 5: camera.capture(f'{user_home}/my_photo%s.jpg' % i)
This block of code handles a KeyboardInterrupt (such as Ctrl+C) by stopping the camera preview. The
passstatement is used to handle the exception without doing anything else.except KeyboardInterrupt: # Stop the camera preview if a KeyboardInterrupt (e.g., Ctrl+C) occurs camera.stop_preview() pass
