SunFounder Ulimate Raphael Kit for Raspberry Pi
latest
About Video Course
Components List and Introduction
Install and Setup Raspberry Pi OS
GPIO Extension Board
Download the Code
Play with Python
Play with C
Install and Check the WiringPi
Output
Input
2.1 Controllers
2.1.1 Button
2.1.2 Micro Switch
2.1.3 Touch Switch Module
2.1.4 Slide Switch
2.1.5 Tilt Switch
2.1.6 Rotary Encoder Module
2.1.7 Potentiometer
2.1.8 Keypad
2.1.9 Joystick
2.2 Sensors
2.2.1 Photoresistor
2.2.2 Thermistor
2.2.3 DHT-11
2.2.4 Reed Switch Module
2.2.5 IR Obstacle Avoidance Module
2.2.6 Speed Sensor Module
2.2.7 PIR
2.2.8 Ultrasonic Sensor Module
2.2.9 MPU6050 Module
2.2.10 MFRC522 RFID Module
Extension
Play with Processing
Play with Nodejs
Play with Scratch
Appendix
Thank You
Docs
Play with C
Input
Edit on GitHub
Input
2.1 Controllers
2.1.1 Button
2.1.2 Micro Switch
2.1.4 Slide Switch
2.1.5 Tilt Switch
2.1.7 Potentiometer
2.1.8 Keypad
2.1.9 Joystick
2.2 Sensors
2.2.1 Photoresistor
2.2.2 Thermistor
2.2.3 DHT-11
2.2.7 PIR
Read the Docs
v: latest
Versions
latest
Downloads
pdf
html
epub
On Read the Docs
Project Home
Builds
Free document hosting provided by
Read the Docs
