2.2.6 Speed Sensor Module
In this project, we will learn the use of the speed sensor module. A Speed Sensor Module is a type of tachometer that is used to measure the speed of a rotating object like a motor.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
Step 2: Change directory.
cd ~/raphael-kit/c/2.2.6/
Step 3: Compile.
gcc 2.2.6_speed_sensor_module.c -lwiringPi
Step 4: Run.
After the code runs, the green LED will light up. If you place an obstacle in the gap of the speed sensor module, the “light blocked” will be printed on the screen and the red LED will be lit. Remove the obstacle and the green LED will light up again.
#include <wiringPi.h>
#include <stdio.h>
#define speedPin 0
#define Gpin 2
#define Rpin 3
void LED(int color)
pinMode(Gpin, OUTPUT);
pinMode(Rpin, OUTPUT);
if (color == 0){
digitalWrite(Rpin, HIGH);
digitalWrite(Gpin, LOW);
else if (color == 1){
digitalWrite(Rpin, LOW);
digitalWrite(Gpin, HIGH);
void Print(int x){
if ( x == 0 ){
printf("Light was blocked\n");
int main(void){
pinMode(speedPin, INPUT);
int temp;
//Reverse the input of speedPin
if ( digitalRead(speedPin) == 0 ){
temp = 1;
if ( digitalRead(speedPin) == 1 ){
temp = 0;
LED(temp);
Print(temp);
Code Explanation
void LED(int color)
if (color == 0){
Set a LED() function to control the 2 LEDs, the parameter of this function is color.
When color is 0, set Rpin to HIGH (light up the red LED) and Gpin to LOW (turn off the green LED); when color is 1, then light up the green LED and turn off the red LED.
temp = 1;
temp = 0;
LED(temp);
Print(temp);
When you place an obstacle in the gap of the speed sensor module, speedPin is low level (0), then call LED(1) function to light up the green LED and “Light was blocked!” is printed.
