2.2.4 Reed Switch Moduleο
Introductionο
In this project, we will learn about the reed switch, which is an electrical switch that operates by means of an applied magnetic field.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Change directory.
cd ~/raphael-kit/c/2.2.4/
Step 3: Compile.
gcc 2.2.4_ReedSwitch.c -lwiringPi
Step 4: Run.
The green LED will light up when the code is run. If a magnet is placed close to the reed switch module, the red LED lights up; take away the magnet and the green LED lights up again.
#include <wiringPi.h>
#include <stdio.h>
#define ReedPin 0
#define Gpin 2
#define Rpin 3
void LED(char* color)
pinMode(Gpin, OUTPUT);
pinMode(Rpin, OUTPUT);
if (color == "RED")
digitalWrite(Rpin, HIGH);
digitalWrite(Gpin, LOW);
else if (color == "GREEN")
digitalWrite(Rpin, LOW);
digitalWrite(Gpin, HIGH);
else
printf("LED Error");
int main(void)
pinMode(ReedPin, INPUT);
LED("GREEN");
if(0 == digitalRead(ReedPin)){
delay(10);
LED("RED");
printf("Detected Magnetic Material!\n");
else if(1 == digitalRead(ReedPin)){
delay(10);
while(!digitalRead(ReedPin));
LED("GREEN");
Code Explanation
#define ReedPin 0
#define Gpin 2
#define Rpin 3
Pin GPIO17, GPIO27 and GPIO22 of the T_Extension Board is corresponding to
the GPIO0, GPIO2 and GPIO3 in wiringPi. Assign GPIO0, GPIO2 and GPIO3 to
ReedPin, Gpin and Rpin.
if (color == "RED")
else
Set a LED() function to control the 2 LEDs, the parameter of this function is color.
When color is "RED", set Rpin to HIGH (light up the red LED) and Gpin to LOW (turn off the green LED); when color is "GREEN", then light up the green LED and turn off the red LED.
delay(10);
LED("RED");
delay(10);
LED("GREEN");
Read the value of the reed switch module, if the value read 2 times is 0, call LED("RED") to light up the red LED and print "Magnetic material detected!".
If the value is 1, the green LED is lit.
