SunFounder Ulimate Raphael Kit for Raspberry Pi
latest
  • About Video Course
  • Components List and Introduction
  • Install and Setup Raspberry Pi OS
  • GPIO Extension Board
  • Download the Code
  • Play with Python
  • Play with C
    • Install and Check the WiringPi
    • Output
      • 1.1 Displays
        • 1.1.1 Blinking LED
        • 1.1.2 RGB LED
        • 1.1.3 LED Bar Graph
        • 1.1.4 7-segment Display
        • 1.1.5 4-Digit 7-Segment Display
        • 1.1.6 LED Dot Matrix Module
        • 1.1.7 I2C LCD1602
      • 1.2 Sound
        • 1.2.1 Active Buzzer
        • 1.2.2 Passive Buzzer
      • 1.3 Drivers
        • 1.3.1 Motor
        • 1.3.2 Servo
        • 1.3.3 Relay
    • Input
    • Extension
  • Play with Processing
  • Play with Nodejs
  • Play with Scratch
  • Appendix
  • Thank You
  • Docs »
  • Play with C »
  • Output
  • Edit on GitHub
Output¶
1.1 Displays¶
  • 1.1.2 RGB LED
  • 1.1.7 I2C LCD1602
1.2 Sound¶
1.3 Drivers¶
  • 1.3.1 Motor
  • 1.3.2 Servo
  • 1.3.3 Relay
Next Previous
© Copyright 2022, SunFounder Revision e57974f8.
Built with Sphinx using a theme provided by Read the Docs.
Read the Docs v: latest
Versions
latest
Downloads
pdf
html
epub
On Read the Docs
Project Home
Builds
Free document hosting provided by Read the Docs.
