1.3.3 Relayο
Introductionο
In this project, we will learn to use a relay. It is one of the commonly used components in automatic control system. When the voltage, current, temperature, pressure, etc., reaches, exceeds or is lower than the predetermined value, the relay will connect or interrupt the circuit, to control and protect the equipment.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Open the code file.
cd ~/raphael-kit/c/1.3.3
Step 3: Compile the code.
gcc 1.3.3_Relay.c -lwiringPi
After the code runs, the LED will light up. In addition, you can hear a ticktock caused by breaking normally close contact and closing normally open contact.
#include <wiringPi.h>
#include <stdio.h>
#define RelayPin 0
int main(void){
if(wiringPiSetup() == -1){ //when initialize wiring failed, print message to screen
pinMode(RelayPin, OUTPUT); //set GPIO17(GPIO0) output
// Tick
printf("Relay Open......\n");
digitalWrite(RelayPin, LOW);
delay(1000);
// Tock
printf("......Relay Close\n");
digitalWrite(RelayPin, HIGH);
delay(1000);
Code Explanation
Set the I/O port as low level (0V), thus the transistor is not energized and the coil is not powered. There is no electromagnetic force, so the relay opens, LED does not turn on.
set the I/O port as high level (5V) to energize the transistor. The coil of the relay is powered and generate electromagnetic force, and the relay closes, LED lights up.
Phenomenon Pictureο
