2.2.5 IR Obstacle Avoidance Module¶
Introduction¶
In this project, we will learn IR obstacle avoidance module, which is a sensor module that can be used to detect obstacles at short distances, with small interference, easy to assemble, easy to use, etc. It can be widely used in robot obstacle avoidance, obstacle avoidance trolley, assembly line counting, etc.
Required Components¶
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram¶
Experimental Procedures¶
Step 1: Build the circuit.
Step 2: Change directory.
cd ~/raphael-kit/c/2.2.5/
Step 3: Compile.
gcc 2.2.5_IrObstacle.c -lwiringPi
Step 4: Run.
After the code runs, when you put your hand in front of the module’s probe, the output indicator on the module lights up and the “Detected Barrier!” will be repeatedly printed on the screen.
#include <wiringPi.h>
#include <stdio.h>
#define ObstaclePin 0
void myISR(void)
printf("Detected Barrier !\n");
int main(void)
printf("setup wiringPi failed !\n");
if(wiringPiISR(ObstaclePin, INT_EDGE_FALLING, &myISR) < 0){
printf("Unable to setup ISR !!!\n");
Code Explanation
void myISR(void)
Define a function myISR()
to print obstacle detected
, indicating that an obstacle is detected.
This wiringPiISR()
function registers a myISR()
function to received interrupts on the specified ObstaclePin
When ObstaclePin changes from high to low, it means that an obstacle is detected. At this time, call the myISR()
function to print “Detected Barrier !”
The prototype of this wiringPiISR()
function is shown below.
int wiringPiISR (int pin, int edgeType, void (*function)(void)) ;
The edgeType parameter is either INT_EDGE_FALLING
, INT_EDGE_RISING
, INT_EDGE_BOTH
or INT_EDGE_SETUP
. If it is INT_EDGE_SETUP
then no initialisation of the pin will happen – it’s assumed that you have already setup the pin elsewhere (e.g. with the gpio program), but if you specify one of the other types, then the pin will be exported and initialised as specified.
For more information, please refer to: wiringPi-Functions (API).
