2.1.3 Touch Switch Module¶
Introduction¶
In this project, you will learn about touch switch module. It can replace the traditional kinds of switch with these advantages: convenient operation, fine touch sense, precise control and least mechanical wear.
Required Components¶
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram¶
Experimental Procedures¶
Step 1: Build the circuit.
Step 2: Change directory.
cd ~/raphael-kit/c/2.1.3/
Step 3: Compile.
gcc 2.1.3_TouchSwitch.c -lwiringPi
Step 4: Run.
While the code is running, the red LED lights up; when you tap on the touch switch module, the yellow LED turns on.
#include <wiringPi.h>
#include <stdio.h>
#define touchPin 0
#define led1 3
#define led2 2
int main(void)
// When initialize wiring failed, print message to screen
if(wiringPiSetup() == -1){
printf(etup w"siringPi failed !");
pinMode(touchPin, INPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
// touch switch high, led1 on
if(digitalRead(touchPin) == 1){
digitalWrite(led1, LOW);
digitalWrite(led2, HIGH);
printf("You touch it! \r\n");
// touch switch low, led2 on
if(digitalRead(touchPin) == 0){
digitalWrite(led2, LOW);
digitalWrite(led1, HIGH);
Code Explanation
#define touchPin 0
#define led1 3
#define led2 2
Pin GPIO17, GPIO22 and GPIO27 of the T_Extension Board is corresponding to
the GPIO0, GPIO3 and GPIO2 in wiringPi. Assign GPIO0, GPIO3 and GPIO2 to
touchPin
, led1
and led2
Set led1
, led2
as output to write value to them and set touchPin
as input to
read value from it.
Set an infinite loop, when you tap on the touch switch module, touchPin
is high, led1 will light up and print “You touch it!” . When touchPin is low, led2 will light up.
