2.1.8 Keypadο
Introductionο
A keypad is a rectangular array of buttons. In this project, We will use it input characters.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Open the code file.
cd ~/raphael-kit/c/2.1.8/
Step 3: Compile the code.
gcc 2.1.8_Keypad.cpp -lwiringPi
Step 4: Run.
After the code runs, the values of pressed buttons on keypad (button Value) will be printed on the screen.
#include <wiringPi.h>
#include <stdio.h>
#define ROWS 4
#define COLS 4
'1','2','3','A',
'4','5','6','B',
'7','8','9','C',
'*','0','#','D'};
unsigned char rowPins[ROWS] = {1, 4, 5, 6};
unsigned char colPins[COLS] = {12, 3, 2, 0};
void init(void) {
for(int i=0 ; i<4 ; i++) {
pinMode(rowPins[i], OUTPUT);
pinMode(colPins[i], INPUT);
int main(void){
unsigned char pressed_keys[BUTTON_NUM];
unsigned char last_key_pressed[BUTTON_NUM];
init();
keyRead(pressed_keys);
if (!comp){
keyPrint(pressed_keys);
keyCopy(last_key_pressed, pressed_keys);
delay(100);
void keyRead(unsigned char* result){
int index;
int count = 0;
keyClear(result);
for(int i=0 ; i<ROWS ; i++ ){
digitalWrite(rowPins[i], HIGH);
for(int j =0 ; j < COLS ; j++){
index = i * ROWS + j;
if(digitalRead(colPins[j]) == 1){
result[count]=KEYS[index];
count += 1;
delay(1);
digitalWrite(rowPins[i], LOW);
bool keyCompare(unsigned char* a, unsigned char* b){
for (int i=0; i<BUTTON_NUM; i++){
if (a[i] != b[i]){
return false;
return true;
void keyCopy(unsigned char* a, unsigned char* b){
a[i] = b[i];
void keyPrint(unsigned char* a){
if (a[0] != 0){
printf("%c",a[0]);
for (int i=1; i<BUTTON_NUM; i++){
if (a[i] != 0){
printf(", %c",a[i]);
printf("\n");
void keyClear(unsigned char* a){
a[i] = 0;
int keyIndexOf(const char value){
if ((const char)KEYS[i] == value){
return i;
return -1;
Code Explanation
'1','2','3','A',
'4','5','6','B',
'7','8','9','C',
'*','0','#','D'};
Declare each key of the matrix keyboard to the array keys[] and define
the pins on each row and column.
if (!comp){
delay(100);
This is the part of the main function that reads and prints the button value.
The function keyRead() will read the state of every button.
KeyCompare() and keyCopy() are used to judge whether the state of a
button has changed (that is, a button has been pressed or released).
keyPrint() will print the button value of the button whose current level
is high level (the button is pressed).
int index;
int count = 0;
keyClear(result);
count += 1;
delay(1);
This function assigns a high level to each row in turn, and when the key
in the column is pressed, the column in which the key is located gets a
high level. After the two-layer loop judgment, the key state compilation
will generate an array (reasult[]).
When pressing button 3:
RowPin [0] writes in the high level, and colPin[2] gets the high level.
ColPin [0], colPin[1], colPin[3] get the low level.
This gives us 0,0,1,0. When rowPin[1], rowPin[2] and rowPin[3] are written in high level, colPin[0]~colPin[4] will get low level.
After the loop judgment is completed, an array will be generated:
result[BUTTON_NUM] {
0, 0, 1, 0,
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0};
if (a[i] != b[i]){
return false;
return true;
a[i] = b[i];
These two functions are used to judge whether the key state has changed, for example when you release your hand when pressing β3β or pressing β2β, keyCompare() returns false.
KeyCopy() is used to re-write the current button value for the a array (last_key_pressed[BUTTON_NUM]) after each comparison. So we can compare them next time.
//printf("{");
if (a[0] != 0){
printf("%c",a[0]);
if (a[i] != 0){
printf("\n");
This function is used to print the value of the button currently pressed. If the button β1β is pressed, the β1β will be printed. If the button β1β is pressed and the button β3β is pressed, the β1, 3β will be printed.
Phenomenon Pictureο
