2.2.2 Thermistor
Just like photoresistor can sense light, thermistor is a temperature sensitive electronic device that can be used for realizing functions of temperature control, such as making a heat alarm.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/c/2.2.2/
Step 3: Compile the code.
gcc 2.2.2_Thermistor.c -lwiringPi -lm
-lm is to load the library math. Do not omit, or you will make an error.
With the code run, the thermistor detects ambient temperature which will be printed on the screen once it finishes the program calculation.
#include <wiringPi.h>
#include <stdio.h>
#include <math.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define ADC_CS 0
#define ADC_CLK 1
#define ADC_DIO 2
uchar i;
uchar dat1=0, dat2=0;
int sel = channel > 1 & 1;
int odd = channel & 1;
digitalWrite(ADC_CLK, 1);
delayMicroseconds(2);
digitalWrite(ADC_CLK, 0);
pinMode(ADC_DIO, OUTPUT);
digitalWrite(ADC_CS, 0);
// Start bit
digitalWrite(ADC_CLK,0);
//Single End mode
// ODD
//Select
for(i=0;i<8;i++)
pinMode(ADC_DIO, INPUT);
for(i=0;i<8;i++)
digitalWrite(ADC_CS,1);
int main(void)
unsigned char analogVal;
pinMode(ADC_CS, OUTPUT);
pinMode(ADC_CLK, OUTPUT);
cel = temp - 273.15;
Fah = cel * 1.8 +32;
printf("Celsius: %.2f C Fahrenheit: %.2f F\n", cel, Fah);
delay(100);
Code Explanation
#include <math.h>
There is a C numerics library which declares a set of functions to compute common mathematical operations and transformations.
This function is used to read the value of the thermistor.
These calculations convert the thermistor values into Celsius values.
These two lines of codes are calculating the voltage distribution with the read value analog so as to get Rt (resistance of thermistor).
This code refers to plugging Rt into the formula TK=1/(ln(RT/RN)/B+1/TN) to get Kelvin temperature.
temp = temp - 273.15;
Convert Kelvin temperature into degree Celsius.
Convert degree Celsius into Fahrenheit.
Print centigrade degree, Fahrenheit degree and their units on the display.
Phenomenon Picture
