2.1.9 Joystick
In this project, We’re going to learn how joystick works. We manipulate the Joystick and display the results on the screen.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
When the data of joystick is read, there are some differents between axis: data of X and Y axis is analog, which need to use ADC0834 to convert the analog value to digital value. Data of Z axis is digital, so you can directly use the GPIO to read, or you can also use ADC to read.
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/c/2.1.9/
Step 3: Compile the code.
gcc 2.1.9_Joystick.c -lwiringPi
After the code runs, turn the Joystick, then the corresponding values of x, y, Btn are displayed on screen.
#include <wiringPi.h>
#include <stdio.h>
#include <softPwm.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define ADC_CS 0
#define ADC_CLK 1
#define ADC_DIO 2
#define BtnPin 3
uchar i;
uchar dat1=0, dat2=0;
int sel = channel > 1 & 1;
int odd = channel & 1;
digitalWrite(ADC_CLK, 1);
delayMicroseconds(2);
digitalWrite(ADC_CLK, 0);
pinMode(ADC_DIO, OUTPUT);
digitalWrite(ADC_CS, 0);
// Start bit
digitalWrite(ADC_CLK,0);
//Single End mode
// ODD
//Select
for(i=0;i<8;i++)
pinMode(ADC_DIO, INPUT);
for(i=0;i<8;i++)
digitalWrite(ADC_CS,1);
int main(void)
uchar x_val;
uchar y_val;
uchar btn_val;
pinMode(BtnPin, INPUT);
pullUpDnControl(BtnPin, PUD_UP);
pinMode(ADC_CS, OUTPUT);
pinMode(ADC_CLK, OUTPUT);
x_val = get_ADC_Result(0);
y_val = get_ADC_Result(1);
btn_val = digitalRead(BtnPin);
printf("x = %d, y = %d, btn = %d\n", x_val, y_val, btn_val);
delay(100);
Code Explanation
uchar i;
// Start bit
//Single End mode
The working process of the function is detailed in 2.1.7 Potentiometer.
delay(100);
VRX and VRY of Joystick are connected to CH0, CH1 of ADC0834 respectively. So the function getResult() is called to read the values of CH0 and CH1. Then the read values should be stored in the variables x_val and y_val. In addition, read the value of SW of joystick and store it into the variable Btn_val. Finally, the values of x_val, y_val and Btn_val shall be printed with print() function.
Phenomenon Picture
