3.1.4 Text-to-speech
In many places, we can come into contact with TTS (Text-to-speech) technology, which converts text into natural-sounding speech and brings people a good interactive experience.
Let’s try to make your project speak.
../_images/audio2.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Audio Module and Speaker
Experimental Procedures
Step 1: Build the circuit.
../_images/4.1.4fritzing1.png
After building the circuit according to the above diagram, then plug the audio cable into the Raspberry Pi’s 3.5mm audio jack.
../_images/audio41.png
Step 2: Install espeak module.
sudo apt-get install espeak -y
Step 3: Get into the folder of the code.
cd ~/raphael-kit/python/
Step 4: Run.
python3 3.1.4_Text-to-speech.py
Raspberry pi will greet you kindly after the code runs, and it will say goodbye to you when the code stops.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect. After confirming that there are no problems, you can use the Copy button to copy the modified code, then open the source code in Terminal via nano cammand and paste it.
from tts import TTS
tts = TTS(engine="espeak")
tts.lang('en-US')
def main():
    tts.say('Hello, nice to meet you!')
def destroy():
    tts.say('See you later')
if __name__ == '__main__':
        main()
        destroy()
Code Explanation
from tts import TTS
Import the TTS class and instantiate an object.
tts.lang('en-US')
Set the language.
Currently the switchable language only supports English.
tts.say("Hello, nice to meet you!")
Fill in the text to be said as a parameter, after executing tts.say(), Raspberry Pi will say the text you wrote.
Phenomenon Picture
../_images/3.1.3audio.JPG
