4.9 Traffic Light Simulation
This project demonstrates the use of LEDs and a 4-digit 7-segment display to simulate a real-world traffic light system. The LEDs represent the red, yellow, and green lights, while the 7-segment display counts down the time remaining for each light. It provides an engaging way to learn about GPIO control, timing, and 7-segment displays in an educational or prototype setting.
What You’ll Need
The following components are required for this project:
COMPONENT INTRODUCTION |
PURCHASE LINK |
Raspberry Pi |
Circuit Diagram
Below is the schematic diagram for the traffic light simulation project:
Wiring Diagram
Refer to the wiring diagram for assembling the components:
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory.
Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 4.9_TrafficLight.py
Here is the Python script for the traffic light simulation:
from fusion_hat.pin import Pin, Mode
import threading
# Setup GPIO pins for 74HC595 shift register
SDI = Pin(17,mode=Mode.OUT) # Serial Data Input
RCLK = Pin(4,mode=Mode.OUT) # Register Clock
SRCLK = Pin(27,mode=Mode.OUT) # Shift Register Clock
# Define GPIO pins for digit selection on the 7-segment display
placePin = [Pin(pin,mode=Mode.OUT) for pin in (23, 24, 25, 12)]
# Segment codes for numbers 0-9 on 7-segment display
# Setup GPIO pins for traffic light LEDs
ledPinR = Pin(5,mode=Mode.OUT) # Red LED
ledPinG = Pin(6,mode=Mode.OUT) # Green LED
ledPinY = Pin(13,mode=Mode.OUT) # Yellow LED
# Duration settings for traffic lights
greenLight = 30
yellowLight = 5
redLight = 60
# Traffic light color names
lightColor = ("Red", "Green", "Yellow")
# Initialize state variables
colorState = 0
counter = 60
timer1 = None
def setup():
""" Initialize the traffic light system and start the timer. """
global timer1
timer1 = threading.Timer(1.0, timer)
timer1.start()
def clearDisplay():
""" Clear the 7-segment display. """
for _ in range(8):
SDI.high()
SRCLK.high()
SRCLK.low()
RCLK.high()
RCLK.low()
def hc595_shift(data):
""" Shift data to the 74HC595 shift register for digit display. """
for i in range(8):
SDI.value(0x80 & (data << i))
SRCLK.high()
SRCLK.low()
RCLK.high()
RCLK.low()
def pickDigit(digit):
""" Select a specific digit to display on the 7-segment display. """
for pin in placePin:
pin.low()
placePin[digit].high()
def timer():
""" Handle the timing for traffic light changes. """
global counter, colorState, timer1
timer1.start()
counter -= 1
if counter == 0:
counter = [greenLight, yellowLight, redLight][colorState]
colorState = (colorState + 1) % 3
print(f"counter : {counter} color: {lightColor[colorState]}")
def lightup():
""" Update the traffic light LED based on the current state. """
global colorState
ledPinR.low()
ledPinG.low()
ledPinY.low()
[ledPinR, ledPinG, ledPinY][colorState].high()
def display():
""" Display the current counter value on the 7-segment display. """
global counter
for i in range(4):
digit = counter // (10 ** (3 - i)) % 10
if i == 0 and digit == 0:
continue
clearDisplay()
pickDigit(i)
hc595_shift(number[digit])
def loop():
""" Main loop to continuously update display and lights. """
display()
lightup()
def destroy():
""" Clean up resources when the script is terminated. """
global timer1
timer1.cancel()
ledPinR.low()
ledPinG.low()
ledPinY.low()
setup()
loop()
destroy()
Understanding the Code
Initialization:
Sets up GPIO pins for the shift register, 7-segment display, and traffic light LEDs.
Defines constants for light durations and initializes state variables.
7-Segment Display Functions:
clearDisplay: Clears all segments on the display.hc595_shift: Sends data to the shift register to control display segments.pickDigit: Activates a specific digit for multiplexing.
Timer Function:
Handles the countdown and transitions between light states.
Traffic Light Control:
Updates the LEDs based on the current state.
Main Loop:
Continuously updates the display and LEDs.
Cleanup:
Ensures all resources are properly released on termination.
Troubleshooting
Traffic Lights Not Working:
Cause: Incorrect wiring or faulty LEDs.
Solution:
Verify that the LEDs are correctly connected to GPIO pins 5 (Red), 6 (Green), and 13 (Yellow).
Test each LED individually using a simple GPIO control script.
7-Segment Display Does Not Show Countdown:
Cause: Incorrect wiring or shift register configuration.
Solution:
Ensure the shift register’s
SDI,RCLK, andSRCLKpins are properly connected to GPIO 17, 4, and 27, respectively.Verify the digit selection pins match the
placePinconfiguration.
Countdown Timer Freezes:
Cause: Timer thread not restarting correctly.
Solution: Ensure the
timer()function callstimer1.start()to restart the timer thread.
Incorrect Light Durations:
Cause: Incorrect duration values or state transitions.
Solution:
Verify the
redLight,greenLight, andyellowLightdurations.Check the
timer()function logic to ensure correct state transitions.
Extendable Ideas
Pedestrian Crossing: Add a pedestrian crossing button that temporarily interrupts the traffic cycle to allow pedestrians to cross safely.
from fusion_hat import Pin pedestrian_button = Pin(22, Pin.IN, Pin.PULL_DOWN) def handle_pedestrian(): global colorState, counter if colorState == 1: # If Green Light counter = 5 # Shorten green light duration pedestrian_button.when_activated = handle_pedestrian
Adaptive Timing: Adjust the durations of the traffic lights dynamically based on real-time traffic density.
Event Logging: Log traffic light state changes with timestamps to a file for analysis:
with open("traffic_log.txt", "a") as log_file: log_file.write(f"{time.strftime('%Y-%m-%d %H:%M:%S')} - {lightColor[colorState]} light\n")
Conclusion
This project simulates a traffic light system, providing hands-on experience with GPIO control, shift registers, and 7-segment displays. It’s a fun and educational way to explore electronics and programming while replicating a real-world application. Try enhancing the system to make it even more interactive!
