1.8 4-Digit 7-Segment Display
In this project, we will learn how to control a 4-digit 7-segment display to create a counter. The counter will increment by 1 every second, and the display will update accordingly. This project highlights the use of GPIO pins and a 74HC595 shift register to manage multiple digits efficiently.
What You’ll Need
To complete this project, you will need the following components:
COMPONENT
PURCHASE LINK
Jumper Wires
Resistor
74HC595
Fusion HAT+
Raspberry Pi
Circuit Diagram
The circuit diagram shows how to connect the 74HC595 shift register to the 4-digit 7-segment display and the Raspberry Pi GPIO pins. The shift register reduces the number of GPIO pins required, allowing efficient control of the display.
../_images/1.1.5_sch.png
Wiring Diagram
Follow these steps to assemble the circuit:
  1. Place the 4-digit 7-segment display and the 74HC595 shift register on the breadboard.
  2. Connect the output pins of the 74HC595 to the segments of the display.
  3. Use Digital pins on the Fusion HAT+ for the data input (SER also called SDI), shift register clock (SRCLK), and latch register clock (RCLK).
  4. Add resistors to limit current for the display segments.
../_images/1.1.5_bb.png
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory. Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 1.8_4-Digit.py
After running the script, the 4-digit 7-segment display shows a counter that increases by one every second. The current counter value is also printed to the console. This continues until you stop the program by pressing Ctrl + C.
The Python code below initializes the display, updates the counter, and manages the display refresh loop:
from fusion_hat.pin import Pin, Mode
import threading
# Define GPIO pins for the 74HC595 shift register
SDI = Pin(17,mode=Mode.OUT)   # Serial Data Input
RCLK = Pin(4,mode=Mode.OUT)  # Register Clock
SRCLK = Pin(27,mode=Mode.OUT) # Shift Register Clock
# Define GPIO pins for digit selection on the 7-segment display
placePin = [Pin(pin,mode=Mode.OUT) for pin in (23, 24, 25, 12)]
# Define segment codes for numbers 0-9 for the 7-segment display
counter = 0  # Initialize counter for display
timer1 = 0   # Initialize timer for counter increment
def clearDisplay():
   """ Clear the 7-segment display. """
   for _ in range(8):
      SDI.high()
      SRCLK.high()
      SRCLK.low()
   RCLK.high()
   RCLK.low()
def hc595_shift(data):
   """ Shift a byte of data to the 74HC595 shift register. """
   for i in range(8):
      SDI.value(0x80 & (data << i))  # Set SDI high/low based on data bit
      SRCLK.high()  # Pulse the Shift Register Clock
      SRCLK.low()
   RCLK.high()  # Latch data on the output by pulsing Register Clock
   RCLK.low()
def pickDigit(digit):
   """ Select a digit for display on the 7-segment display. """
   for pin in placePin:
      pin.low()  # Turn off all digit selection pins
   placePin[digit].high()  # Turn on the selected digit
def timer():
   """ Timer function to increment the counter every second. """
   global counter, timer1
   timer1 = threading.Timer(1.0, timer)  # Reset timer for next increment
   timer1.start()
   counter += 1  # Increment counter
   print("%d" % counter)  # Print current counter value
def setup():
   """ Setup initial state and start the timer. """
   global timer1
   timer1 = threading.Timer(1.0, timer)  # Initialize and start the timer
   timer1.start()
def loop():
   """ Main loop to update the 7-segment display with counter value. """
   global counter
      for i in range(4):  # Loop through each digit
            clearDisplay()  # Clear display before setting new digit
            pickDigit(i)    # Select digit for display
            # Choose the digit of counter to display
            digit = (counter // (10 ** (3-i))) % 10
            hc595_shift(number[digit])  # Shift digit value to 74HC595
            time.sleep(0.001)  # Short delay for display stability
def destroy():
   """ Cleanup GPIO resources and stop timer on exit. """
   global timer1
   timer1.cancel()  # Stop the timer
   for device in [SDI, RCLK, SRCLK] + placePin:
      device.close()  # Close GPIO devices
   setup()  # Initialize the setup
      loop()  # Start the main loop
   # Handle script interruption (e.g., Ctrl+C)
   destroy()  # Cleanup resources on exit
This Python script controls a 4-digit 7-segment display using a Raspberry Pi and a 74HC595 shift register. When executed:
  1. The display shows an incrementing counter, with digits updating every second.
  2. The counter value is printed to the console for debugging purposes.
The program runs indefinitely, incrementing the displayed counter until the user interrupts the script by pressing Ctrl+C.
Understanding the Code
  1. Initialize GPIO Pins
    Assign GPIO pins for the shift register and digit selection.
    SDI = Pin(17,Pin.OUT)   # Serial Data Input
    RCLK = Pin(4,Pin.OUT)  # Register Clock
    SRCLK = Pin(27,Pin.OUT) # Shift Register Clock
  2. Segment Codes
    The number array defines the binary representation for digits 0-9.
  3. Display Refresh
    The loop function continuously updates the display by selecting each digit and sending the appropriate data.
    def loop():
       global counter
          for i in range(4):
             clearDisplay()
             pickDigit(i)
             time.sleep(0.001)
  4. Counter Update
    The timer function increments the counter every second.
    def timer():
       timer1.start()
       counter += 1
  5. Cleanup
    The destroy function stops the timer and releases GPIO resources on program exit.
    def destroy():
       global timer1
Troubleshooting
  1. Display Shows Nothing
    • Cause: Incorrect wiring or GPIO pin configuration.
    • Solution: Double-check the connections to the 74HC595 shift register and ensure the GPIO pins (17, 4, 27) match the defined variables (SDI, RCLK, SRCLK).
  2. Digits Do Not Update Correctly
    • Cause: Timing issues or incorrect multiplexing.
    • Solution: Ensure that the time.sleep(0.001) in the loop() function is sufficient for stable display updates.
  3. Counter Resets Unexpectedly
    • Cause: The timer1 threading timer may not be running properly.
    • Solution: Confirm that the setup() function is executed before the main loop() and that the timer is started correctly.
  4. KeyboardInterrupt Not Working
    • Cause: The destroy() function may not execute properly on interruption.
    • Solution: Ensure all GPIO devices are properly closed in destroy() and that it is called in the except KeyboardInterrupt block.
Extendable Ideas
  1. Custom Counter Behavior
    Modify the counter to count down, reset at a specific value, or display specific patterns.
  2. Multi-Mode Display
    Add different display modes, such as:
    • Static message display.
    • Alternating between the counter and a predefined message.
  3. Variable Counter Speed
    Allow the user to change the counter increment speed dynamically:
    speed = float(input("Enter counter speed in seconds: "))
    timer1 = threading.Timer(speed, timer)
  4. Real-Time Clock
    Replace the counter with a real-time clock to display the current time:
    from datetime import datetime
    now = datetime.now()
    counter = now.hour * 100 + now.minute  # Display as HHMM
Conclusion
This project demonstrates how to control a 4-digit 7-segment display using a 74HC595 shift register and GPIO programming. The skills learned here can be applied to more complex displays and interactive systems.
