1.9 NeoPixel LED Strip
In this project, we will learn how to control an addressable RGB LED strip (NeoPixel) using SPI communication on a Raspberry Pi. NeoPixels are intelligent RGB LEDs that contain their own drivers, allowing individual control of each LED in a chain. This project demonstrates basic color control and filling the entire strip with different colors.
What You’ll Need
To complete this project, you will need the following components:
COMPONENT
PURCHASE LINK
Circular WS2812 LED Module
Jumper Wires
Fusion HAT+
Raspberry Pi
Wiring Diagram
../_images/1.9_ws2812_bb.png
Setup Steps
  1. Before running the code, you need to install the required library:
    This library provides the necessary functions to control NeoPixel LEDs using SPI communication.
    sudo pip3 install adafruit-circuitpython-neopixel-spi --break
  2. All example code used in this tutorial is available in the ai-lab-kit directory. Follow these steps to run the example:
    cd ~/ai-lab-kit/python/
    sudo python3 1.9_NeoPixel.py
  3. When this script runs, the WS2812 LED module cycles through three solid colors:
    • All LEDs turn red for one second
    • All LEDs turn green for one second
    • All LEDs turn blue for one second
    After displaying each color, the LEDs briefly turn off before repeating the cycle. The terminal prints the current color name as the pattern runs.
The following Python code controls a NeoPixel LED strip, cycling through different colors:
import time               # Used for delays
import board              # Provides board-specific pin definitions
import neopixel_spi as neopixel   # NeoPixel SPI driver
# Create an SPI object using the default SPI bus of the board
spi = board.SPI()
LED_COUNT = 12  # Number of LED pixels in the strip
PIXEL_ORDER = neopixel.GRB  # Color order used by the LEDs (Green, Red, Blue)
# Create a NeoPixel strip object over SPI
# auto_write=False means we must call strip.show() to update the LEDs
strip = neopixel.NeoPixel_SPI(spi, LED_COUNT, pixel_order=PIXEL_ORDER, auto_write=False)
time.sleep(0.01)   # Short delay to ensure the strip is ready
strip.fill(0)      # Turn all pixels off (color value 0 = off)
strip.show()       # Send the data to the LED strip
      print("RGB test")
      # Display red on all LEDs
      print("Red")
      strip.fill((255, 0, 0))  # Full red, no green, no blue
      strip.show()
      time.sleep(1)
      # Display green on all LEDs
      print("Green")
      strip.fill((0, 255, 0))  # Full green
      strip.show()
      time.sleep(1)
      # Display blue on all LEDs
      print("Blue")
      strip.fill((0, 0, 255))  # Full blue
      strip.show()
      time.sleep(1)
      # Turn all LEDs off
      # print("Off for 10 seconds")
      strip.fill((0, 0, 0))    # All channels 0 = off
      strip.show()
      time.sleep(1)
# Gracefully handle script termination (e.g., via KeyboardInterrupt)
This Python script demonstrates basic control of a 12-LED WS2812 ring using the NeoPixel SPI driver. When executed:
  1. The script initializes the SPI interface and prepares the WS2812 LED ring.
  2. All LEDs cycle through red, green, and blue with 1-second intervals.
  3. Each color change is printed to the console for debugging.
  4. The LEDs briefly turn off between cycles.
  5. The program loops continuously until interrupted with Ctrl+C.
Understanding the Code
  1. Library Import
    The script uses the neopixel_spi library to control WS2812 LEDs through Raspberry Pi’s SPI interface.
    import board
  2. SPI and NeoPixel Setup
    The SPI bus is initialized and the NeoPixel ring is configured with 12 LEDs and the required color order (GRB).
    spi = board.SPI()
    LED_COUNT = 12
        spi,
        LED_COUNT,
        auto_write=False
  3. Initial LED Reset
    A short delay ensures the LEDs are ready, then all pixels are turned off.
    time.sleep(0.01)
    strip.fill(0)
    strip.show()
  4. Main Color-Cycling Loop
    Inside the infinite loop, the script fills the LED ring with solid red, green, and blue in sequence. Each change is displayed for one second.
        strip.fill((255, 0, 0))  # Red
        strip.show()
        time.sleep(1)
        # Similar code for green and blue...
5. Color Format
Colors are defined using an RGB tuple: (red, green, blue) with each value between 0–255.
strip.fill((0, 255, 0))  # Example: green
Troubleshooting
  • LED Ring Not Lighting Correctly
    • Cause: Wrong wiring or insufficient power
    • Solution: Ensure VCC is 5V, GND is shared, and the data line is connected to DIN (sometimes labeled RGB)
  • Incorrect Colors
    • Cause: LED color order mismatch
    • Solution: Try different pixel orders such as neopixel.RGB or neopixel.GRBW
  • SPI Not Working
    • Cause: SPI disabled or hardware conflict
    • Solution: Enable SPI via sudo raspi-config
  • Library Import Fails
    • Cause: Missing dependency
    • Solution:
Extendable Ideas
  • You can light up specific LEDs with different colors to create simple patterns or highlight certain positions on the ring.
    strip[0] = (255, 0, 0)
    strip.show()
  • By cycling through calculated RGB values, you can generate a smooth rainbow transition across all LEDs.
    strip.fill(wheel(50))
    strip.show()
  • Create a chasing effect by lighting one LED at a time while keeping the others off.
    strip[i] = (0, 255, 0)
    strip.show()
  • You can dim or brighten the entire LED ring by adjusting the brightness attribute.
    strip.brightness = 0.3
Conclusion
This example demonstrates how to control a WS2812 12-LED ring using SPI on a Raspberry Pi. With only a few lines of code, you can cycle through colors, create animations, and explore individual LED control. This makes WS2812 rings ideal for indicator lights, robotics, decorative effects, and interactive visual projects.
