4.12 Environment Monitor
In this lesson, you will build an Environment Monitor Dashboard that reads temperature, humidity, and ambient light level, and displays all values in real time on a 128×64 OLED screen.
This project uses:
  • DHT11 sensor to measure temperature and humidity
  • LDR (Light Dependent Resistor) connected to the Fusion HAT+ ADC to measure light level
  • SSD1306 OLED to display environmental data and a dynamic light bar
The screen updates continuously and shows a status indicator (OK or TIMEOUT) depending on whether the DHT11 provides a valid reading.
What You’ll Need
The following components are required for this project:
COMPONENT INTRODUCTION
PURCHASE LINK
Jumper Wires
Humiture Sensor Module
Photoresistor
OLED Display Module
Fusion HAT+
Raspberry Pi
Wiring Diagram
Refer to the wiring diagram for assembling the components:
../_images/4.12_room_monitor_bb.png
Setup Steps
  1. Install the required libraries:
    sudo pip3 install adafruit-circuitpython-ssd1306 --break
  2. Run the example code from the ai-lab-kit directory:
    cd ~/ai-lab-kit/python/
    sudo python3 4.12_RoomMonitor.py
  3. When the script runs:
    • The OLED shows temperature, humidity, and light percentage
    • A horizontal bar graph displays the current light level
    • “OK” or “TIMEOUT” indicates DHT11 read status
    • Data updates every 0.5 seconds
    • Press Ctrl+C to exit and clear the display
Here is the Python script for the environment monitor dashboard:
from statistics import mean
from fusion_hat.modules import DHT11
from fusion_hat.adc import ADC
from PIL import Image, ImageDraw, ImageFont
import adafruit_ssd1306
import board
# ---------- Hardware configuration ----------
DHT_PIN = 17          # BCM numbering for the DHT11 data pin
LDR_CH  = 0           # ADC channel for LDR (e.g., 0,1, ...)
I2C_ADDR = 0x3C       # OLED I2C address (commonly 0x3C)
# ---------- OLED setup ----------
WIDTH, HEIGHT = 128, 64
i2c = board.I2C()
oled = adafruit_ssd1306.SSD1306_I2C(WIDTH, HEIGHT, i2c, addr=I2C_ADDR)
oled.fill(0)
oled.show()
# Framebuffer
image = Image.new("1", (WIDTH, HEIGHT))
draw = ImageDraw.Draw(image)
font  = ImageFont.load_default()
def text_size(font, text):
   l, t, r, b = font.getbbox(text)
   return (r - l, b - t)
# ---------- Sensors ----------
dht = DHT11(pin=DHT_PIN)
ldr = ADC(LDR_CH)
# ---------- Light normalization ----------
# Map ADC raw (0..4095) to percentage (0..100). You can adjust the calibration
# range to your circuit by putting typical min/max readings below:
LDR_RAW_MIN = 0       # raw value in darkness  (tune if needed)
LDR_RAW_MAX = 4095    # raw value in bright light (tune if needed)
def clamp(v, vmin, vmax):
   return vmax if v > vmax else vmin if v < vmin else v
def linear_map(x, in_min, in_max, out_min, out_max):
   if in_max == in_min:
      return out_min
# Simple moving average for light to reduce flicker
_light_window = []
def light_percent(raw):
   """Convert raw ADC to smoothed light percentage."""
   global _light_window
   # Windowed average of last few samples
   _light_window.append(raw)
   if len(_light_window) > 5:
      _light_window.pop(0)
   smooth_raw = int(mean(_light_window))
   pct = linear_map(smooth_raw, LDR_RAW_MIN, LDR_RAW_MAX, 0, 100)
   return int(clamp(pct, 0, 100)), smooth_raw
# ---------- UI drawing ----------
BAR_W, BAR_H = WIDTH - 16, 10   # width/height for the light bar
BAR_X, BAR_Y = 8, HEIGHT - 12   # position of the light bar
def draw_bar(x, y, w, h, percent):
   """Draw a horizontal bar [0..100]%."""
   # Border
   draw.rectangle((x, y, x + w, y + h), outline=255, fill=0)
   # Fill
   fill_w = int((w - 2) * percent / 100.0)
   if fill_w > 0:
      draw.rectangle((x + 1, y + 1, x + 1 + fill_w, y + h - 1), outline=0, fill=255)
def render_screen(temp_c, hum_pct, light_pct, raw_adc, status_text="OK"):
   """Render all text and graphics to the framebuffer."""
   draw.rectangle((0, 0, WIDTH, HEIGHT), outline=0, fill=0)
   # Title
   title = "Env Monitor"
   tw, th = text_size(font, title)
   draw.text(((WIDTH - tw) // 2, 0), title, font=font, fill=255)
   # Temperature & Humidity lines
   line1 = f"Temp: {temp_c:.1f} degC"
   line2 = f"Hum : {hum_pct:.1f} %"
   draw.text((2, 16), line1, font=font, fill=255)
   draw.text((2, 28), line2, font=font, fill=255)
   # Light line and bar
   line3 = f"Light: {light_pct:3d}%  (raw {raw_adc})"
   draw.text((2, 40), line3, font=font, fill=255)
   draw_bar(BAR_X, BAR_Y, BAR_W, BAR_H, light_pct)
   # Status (e.g., "OK" or "TIMEOUT")
   sw, sh = text_size(font, status_text)
   draw.text((WIDTH - sw - 2, 0), status_text, font=font, fill=255)
# ---------- Main loop ----------
# Keep last good readings so display stays meaningful if a DHT read times out
last_temp = 0.0
last_hum  = 0.0
      # Read DHT11 (may return None / timeout)
      status = "OK"
      result = dht.read()
      if result:
            hum, temp = result  # order per your DHT11 wrapper: (humidity, temperature)
            last_temp, last_hum = float(temp), float(hum)
            status = "TIMEOUT"
      # Read LDR
      raw = ldr.read()
      light_pct, raw_smooth = light_percent(raw)
      # Draw to OLED
      render_screen(last_temp, last_hum, light_pct, raw_smooth, status_text=status)
      oled.image(image)
      oled.show()
      # Console log (optional)
      # print(f"T={last_temp:.1f}C  H={last_hum:.1f}%  Light={light_pct}% (raw {raw_smooth})  [{status}]")
      time.sleep(0.5)
   oled.fill(0)
   oled.show()
   print("\nExited.")
Understanding the Code
  1. Imports
    The script uses several modules:
    • DHT11 for temperature/humidity sensing
    • ADC to read LDR brightness from analog input
    • PIL for OLED drawing
    • adafruit_ssd1306 for OLED control
    • mean() for smoothing light readings
  2. OLED Setup
    A 128×64 SSD1306 OLED is initialized using I2C. A framebuffer (Pillow image) is used to draw all UI elements before sending them to the display.
    i2c = board.I2C()
    oled.fill(0)
    oled.show()
    # Framebuffer
  3. Sensor Reading
    • The DHT11 may occasionally fail. When this happens, the script shows TIMEOUT but retains the last valid values.
    • The LDR raw reading (0..4095) is smoothed using a moving average to reduce flicker.
    status = "OK"
    result = dht.read()
    if result:
       status = "TIMEOUT"
    # Read LDR
    raw = ldr.read()
  4. Light Mapping
    linear_map() converts the raw ADC value into a percentage (0..100%). clamp() ensures the final value stays in range.
  5. Rendering the Dashboard
    The OLED displays:
    • Title
    • Temperature (°C)
    • Humidity (%)
    • Light percentage and raw ADC value
    • A horizontal bar graph for light intensity
    • Status text indicating sensor health
       # Title
  6. Main Loop
    Every 0.5 seconds:
    • DHT11 is read
    • LDR is read and smoothed
    • Screen is updated
    • Optional debug logs can be printed
  7. Graceful Shutdown
    Upon Ctrl+C:
    • OLED is cleared
    • A message is printed
Troubleshooting
  • DHT11 returns TIMEOUT frequently
    • Increase delay between reads
    • Check wiring and signal pin
    • Ensure pull-up resistor is used if needed
  • OLED stays blank
    • Verify I2C address (0x3C)
    • Check SDA/SCL wiring
    • Ensure libraries are installed correctly
  • Light percentage seems inverted
    • Swap LDR_RAW_MIN and LDR_RAW_MAX
    • Check LDR circuit orientation (voltage divider)
  • Display flicker
    • Increase light smoothing window
    • Reduce refresh rate (use time.sleep(1.0))
Try It Yourself
  1. Add Fahrenheit display (°F)
    Show both °C and °F on the screen.
  2. Add max/min history
    Track highest/lowest temperature, humidity, or brightness.
  3. Add alert system
    Flash the OLED border when humidity is too low or temperature too high.
  4. Add graphing mode
    Draw scrolling graphs for temperature and humidity trends.
  5. Add animated icons
    Use small bitmaps for sun, rain, thermometer, humidity droplets, etc.
These ideas turn the simple environment monitor into a feature-rich environmental dashboard.
