πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
3.3 Fusion HAT+ Speaker
The Fusion HAT+ includes a built-in speaker, making it ideal for voice prompts, alarms, and other AI/IoT audio applications. This lesson shows you how to enable, test, and use the speaker with text-to-speech.
This guide assumes Raspberry Pi OS is installed and the Fusion HAT+ drivers are properly set up.
../_images/fusionhat_speaker.png
What You’ll Need
COMPONENT
PURCHASE LINK
Fusion HAT+
Raspberry Pi
Check if the Speaker Is Recognized
Check whether the Fusion HAT+ audio device is detected by the system:
aplay -l
You should see an audio device similar to:
card 3: voicehat [Fusion HAT+ Audio], device 0: ...
If a device named voicehat (or similar) appears under any card number, the Fusion HAT+ audio hardware is successfully recognized.
Run the Example Program
The most reliable way to test the speaker is to run the text-to-speech example.
cd ~/ai-lab-kit/llm
sudo python3 tts_espeak.py
You should hear: β€œHello! I’m Espeak TTS.”
Try adjusting the TTS parameters in the script to hear different voice effects.
Example Code
from fusion_hat.tts import Espeak
tts = Espeak()
tts.set_amp(200)
tts.set_speed(150)
tts.set_gap(1)
tts.set_pitch(80)
tts.say("Hello! I’m Espeak TTS.")
Code Explanation
  • set_amp(0–200) β€” volume
  • set_speed(80–260) β€” speaking speed
  • set_gap(0–200) β€” pause between words
  • set_pitch(0–99) β€” pitch of the voice
  • say() β€” convert text to speech and play it
Tip
Increase speed + pitch to make the voice cheerful; lower both for a deeper, more serious tone.
Troubleshooting
  • No sound output
    • Make sure the Fusion HAT+ audio device is detected:
       aplay -l
    You should see an audio device named ``voicehat`` (or similar).
    If the device is not listed, power off the Raspberry Pi, reseat the
    Fusion HAT+, and reboot.
    • If the device is still not detected, reinstall the audio driver:
    sudo /opt/setup_fusion_hat_audio.sh
  • Text-to-speech sounds too fast or robotic
    • Adjust the speech parameters in the code:
      tts.set_speed(120)
      tts.set_pitch(60)
  • Permission denied error
    • Run the script with superuser privileges:
Summary
In this lesson, you learned how to:
  • Verify that the Fusion HAT+ speaker is recognized
  • Use Espeak TTS to generate speech on the Raspberry Pi
The Fusion HAT+ speaker provides a simple and powerful way to add audio to your Raspberry Pi projects.
