4.11 Servo Angle Meter
In this lesson, you will build a Servo Angle Meter — a visual servo angle indicator that uses a potentiometer to control a servo motor, while displaying the current angle on an OLED screen. The potentiometer provides an analog voltage through the Fusion HAT+’s ADC interface. The servo receives commands based on this reading, and a 128×64 I2C OLED screen shows the numeric servo angle and a graphical bar that moves smoothly across the display.
As you rotate the potentiometer, the servo sweeps between approximately -90° and +90°, and the OLED updates in real time.
What You’ll Need
The following components are required for this project:
COMPONENT INTRODUCTION
PURCHASE LINK
Jumper Wires
Potentiometer
Servo
OLED Display Module
Fusion HAT+
Raspberry Pi
Wiring Diagram
Refer to the wiring diagram for assembling the components:
../_images/4.11_servo_angle_meter_bb.png
Setup Steps
  1. Install the required libraries:
    sudo pip3 install adafruit-circuitpython-ssd1306 --break
  2. All example code used in this tutorial is available in the ai-lab-kit directory:
    cd ~/ai-lab-kit/python/
    sudo python3 4.11_ServoAngleMeter.py
  3. When the script runs:
    • Rotating the potentiometer moves the servo between -90° and +90°.
    • The OLED shows the numeric angle and a moving bar pointer.
    • Ctrl+C exits, resets servo to 0°, and clears the display.
Here is the Python script for the Servo Angle Meter:
from fusion_hat.adc import ADC
from fusion_hat.servo import Servo
from PIL import Image, ImageDraw, ImageFont
import adafruit_ssd1306
import board, time
# ==== OLED setup ====
WIDTH, HEIGHT = 128, 64
i2c = board.I2C()
oled = adafruit_ssd1306.SSD1306_I2C(WIDTH, HEIGHT, i2c, addr=0x3C)
oled.fill(0)
oled.show()
# Framebuffer for drawing
image = Image.new("1", (WIDTH, HEIGHT))
draw = ImageDraw.Draw(image)
font = ImageFont.load_default()
def text_size(font, text):
    l, t, r, b = font.getbbox(text)
    return (r - l, b - t)
# ==== Servo & potentiometer ====
servo = Servo('P0')   # servo on port P0
pot   = ADC('A0')     # potentiometer on A0 (0..4095)
def linear_map(x, in_min, in_max, out_min, out_max):
    """Map x from one range to another."""
# ---- bar layout ----
BAR_TOP     = 40
BAR_HEIGHT  = 10
BAR_MARGINX = 6
BAR_WIDTH   = WIDTH - BAR_MARGINX * 2
BAR_CENTERX = BAR_MARGINX + BAR_WIDTH // 2
def draw_bar(angle_deg):
    """Draw a centered horizontal bar and pointer for -90..90 degrees."""
    draw.rectangle((0, 0, WIDTH, HEIGHT), outline=0, fill=0)
    # Title
    title = "Servo Angle"
    tw, th = text_size(font, title)
    draw.text(((WIDTH - tw) // 2, 4), title, font=font, fill=255)
    # Numeric angle
    txt = f"{angle_deg:>4} deg"
    nw, nh = text_size(font, txt)
    draw.text(((WIDTH - nw) // 2, 20), txt, font=font, fill=255)
    # Bar outline
    draw.rectangle(
        (BAR_MARGINX, BAR_TOP, BAR_MARGINX + BAR_WIDTH - 1, BAR_TOP + BAR_HEIGHT),
        outline=255, fill=0
    # Ticks
    for x in (BAR_MARGINX, BAR_CENTERX, BAR_MARGINX + BAR_WIDTH - 1):
        draw.line((x, BAR_TOP - 3, x, BAR_TOP + BAR_HEIGHT + 3), fill=255)
    # Map angle to pixel position
    pos = int(linear_map(angle_deg, -90, 90, BAR_MARGINX, BAR_MARGINX + BAR_WIDTH - 1))
    draw.line((pos, BAR_TOP - 2, pos, BAR_TOP + BAR_HEIGHT + 2), fill=255)
    # Fill direction highlight
    if pos >= BAR_CENTERX:
        draw.rectangle((BAR_CENTERX, BAR_TOP + 1, pos, BAR_TOP + BAR_HEIGHT - 1), fill=255)
        draw.rectangle((pos, BAR_TOP + 1, BAR_CENTERX, BAR_TOP + BAR_HEIGHT - 1), fill=255)
        raw = pot.read()
        angle = int(linear_map(raw, 0, 4095, -90, 90))
        servo.angle(angle)
        draw_bar(angle)
        oled.image(image)
        oled.show()
        time.sleep(0.05)
    servo.angle(0)
    oled.fill(0)
    oled.show()
    print("\nExited.")
Understanding the Code
  1. Imports
    • ADC reads analog values from the potentiometer
    • Servo controls servo rotation
    • PIL handles all OLED graphics
    • adafruit_ssd1306 drives the I2C OLED display
    • board provides hardware I/O
    • time controls loop speed
  2. OLED Setup
    A 128×64 SSD1306 OLED is initialized and cleared. An off-screen framebuffer holds the graphics for each frame before being pushed to the display.
    i2c = board.I2C()
    oled.fill(0)
    oled.show()
  3. Servo & Potentiometer
    • Servo connected to port P0
    • Potentiometer connected to analog input A0
    • ADC range: 0..4095
  4. Mapping Values
    linear_map() converts the potentiometer reading into a servo angle in the range -90..90.
  5. Drawing the UI
    The draw_bar() function:
    • Clears the display
    • Draws the title
    • Shows numeric angle
    • Draws a horizontal bar and tick marks
    • Draws a pointer and filled segment indicating the angle direction
       Draw a centered horizontal bar with a moving pointer.
       -90° maps to the far left, +90° to the far right.
       0° is at the bar center.
       # Clear screen
       # Title
       # Numeric angle
       # Static bar background
       draw.rectangle(
          outline=255, fill=0
       # Ticks: left (-90), center (0), right (+90)
       # Map angle (-90..90) to bar position
       # Pointer: a solid vertical line
       # Optional: filled segment from center to pointer (visualize direction)
          draw.rectangle((BAR_CENTERX, BAR_TOP + 1, pos, BAR_TOP + BAR_HEIGHT - 1), outline=0, fill=255)
          draw.rectangle((pos, BAR_TOP + 1, BAR_CENTERX, BAR_TOP + BAR_HEIGHT - 1), outline=0, fill=255)
  6. Main Loop
    The script repeatedly:
    • Reads the ADC
    • Computes servo angle
    • Updates servo
    • Draws updated UI
    • Refreshes OLED
       # Read potentiometer (0..4095) and map to angle (-90..90)
       raw = pot.read()
       # Drive servo
       servo.angle(angle)
       # Draw UI and push to OLED
       draw_bar(angle)
       oled.image(image)
       oled.show()
       # Optional: print for debugging
       # print(f"pot={raw:4d} -> angle={angle:4d} deg")
       time.sleep(0.05)  # ~20 FPS
  7. Graceful Exit
    Ctrl+C:
    • Servo returns to 0°
    • OLED is cleared
Troubleshooting
  • OLED shows nothing
    • Check I2C wiring
    • Verify device address is 0x3C
    • Ensure required libraries are installed
  • Servo does not respond
    • Check servo power
    • Confirm servo is connected to P0
    • Ensure servo signal wire is correct
  • Movement range incorrect
    Adjust:
  • OLED flickers
    Increase delay:
    time.sleep(0.1)
Try It Yourself
  1. Add servo angle limits
    Prevent mechanical overdrive.
  2. Add calibration
    Detect min/max potentiometer values dynamically.
  3. Smooth motion
    Apply easing or low-pass filtering.
  4. More display info
    Show raw ADC value alongside angle.
  5. Warnings
    Blink pointer near limits (±75°).
These additions turn the Servo Angle Meter into a highly capable input-visualization tool.
