1.10 OLED Display
In this project, we will learn how to interface with an SSD1306-based OLED display using I2C communication on a Raspberry Pi. OLED (Organic Light-Emitting Diode) displays are known for their high contrast, wide viewing angles, and low power consumption. This project demonstrates how to initialize the display, draw basic shapes, and render text.
What You’ll Need
To complete this project, you will need the following components:
COMPONENT |
PURCHASE LINK |
Raspberry Pi |
Wiring Diagram
Follow these steps to build the circuit:
Connect the VCC pin of OLED display to 3.3V on Fusion HAT+
Connect the GND pin of OLED display to GND on Fusion HAT+
Connect the SCL pin of OLED display to SCL (GPIO 3) on Fusion HAT+
Connect the SDA pin of OLED display to SDA (GPIO 2) on Fusion HAT+
Setup Steps
Install the SSD1306 driver library:
This library enables communication with SSD1306 OLED displays using Python.
sudo pip3 install adafruit-circuitpython-ssd1306 --break
All example programs are included in the
ai-lab-kitdirectory. Run the OLED example as follows:cd ~/ai-lab-kit/python/ sudo python3 1.10_OLED_Display.py
When the example runs, the OLED screen will display a framed box with the text “Hello World!” centered inside it.
This confirms that the display is successfully communicating over I2C and can render text and graphics.
The following Python code initializes an OLED display and draws “Hello World!” text:
import board
import digitalio
from PIL import Image, ImageDraw, ImageFont
import adafruit_ssd1306
# Initialize OLED display dimensions
WIDTH = 128
HEIGHT = 64
# Set up I2C communication with the OLED display
i2c = board.I2C() # Utilizes board's SCL and SDA pins
oled = adafruit_ssd1306.SSD1306_I2C(WIDTH, HEIGHT, i2c, addr=0x3C)
# Clear the OLED display
oled.fill(0)
oled.show()
# Create a new image with 1-bit color for drawing
image = Image.new("1", (oled.width, oled.height))
# Obtain a drawing object to manipulate the image
draw = ImageDraw.Draw(image)
# Draw a filled white rectangle as the background
draw.rectangle((0, 0, oled.width, oled.height), outline=255, fill=255)
# Define border size for an inner rectangle
BORDER = 5
# Draw a smaller black rectangle inside the larger one
draw.rectangle(
(BORDER, BORDER, oled.width - BORDER - 1, oled.height - BORDER - 1),
outline=0,
fill=0,
# Load the default font for text
font = ImageFont.load_default()
def getfontsize(font, text):
# Calculate the size of the text in pixels
left, top, right, bottom = font.getbbox(text)
return right - left, bottom - top
# Define the text to be displayed
text = "Hello World!"
# Get the width and height of the text in pixels
(font_width, font_height) = getfontsize(font, text)
# Draw the text, centered on the display
draw.text(
(oled.width // 2 - font_width // 2, oled.height // 2 - font_height // 2),
text,
font=font,
fill=255,
# Send the image to the OLED display
oled.image(image)
oled.show()
This Python script creates a “Hello World!” display on an SSD1306 OLED screen. When executed:
The script initializes I2C communication with the OLED display
Creates a black-and-white image buffer for drawing
Draws a white background with a black bordered rectangle
Calculates text positioning to center “Hello World!” on the display
Renders the final image to the OLED display
The display shows the text until powered off or updated
Understanding the Code
Library Import
The code imports necessary libraries for display control and image manipulation.
import board import digitalio from PIL import Image, ImageDraw, ImageFont import adafruit_ssd1306
Display Initialization
The OLED display is initialized with specified dimensions and I2C address.
WIDTH = 128 HEIGHT = 64 i2c = board.I2C() oled = adafruit_ssd1306.SSD1306_I2C(WIDTH, HEIGHT, i2c, addr=0x3C)
Display Clearing
The display is cleared by filling it with zeros (black) and updating.
oled.fill(0) oled.show()
Image Buffer Creation
A 1-bit color image buffer is created for drawing operations.
image = Image.new("1", (oled.width, oled.height)) draw = ImageDraw.Draw(image)
Drawing Operations
Rectangles and text are drawn onto the image buffer.
# Background rectangle draw.rectangle((0, 0, oled.width, oled.height), outline=255, fill=255) # Inner bordered rectangle draw.rectangle((BORDER, BORDER, oled.width - BORDER - 1, oled.height - BORDER - 1), outline=0, fill=0)
Text Rendering
Text is centered on the display using font metrics.
font = ImageFont.load_default() (font_width, font_height) = getfontsize(font, text) draw.text((oled.width // 2 - font_width // 2, oled.height // 2 - font_height // 2), text, font=font, fill=255)
Display Update
The final image is sent to the OLED display.
oled.image(image) oled.show()
Troubleshooting
Display Not Showing Anything
Cause: Incorrect I2C address, wiring issues, or I2C not enabled.
Solution: Verify I2C address (try 0x3C or 0x3D), check all connections, and enable I2C in Raspberry Pi configuration (
sudo raspi-config).
I2C Communication Errors
Cause: I2C bus issues or device not detected.
Solution: Check if device is detected with
i2cdetect -y 1command. Ensure no other devices are conflicting on the I2C bus.
Text or Graphics Not Displaying Correctly
Cause: Incorrect color values or coordinate issues.
Solution: Remember that 0=black and 255=white in 1-bit color mode. Verify coordinates are within display boundaries (0-127 for width, 0-63 for height).
Library Import Errors
Cause: Missing dependencies or incorrect installation.
Solution: Ensure all required libraries are installed in the correct environment and try running with
sudoif permission issues occur.
Extendable Ideas
System Information Display
Create a real-time system monitor showing CPU usage, memory, and temperature:
import psutil import time while True: # Clear and redraw draw.rectangle((0, 0, oled.width, oled.height), fill=0) # Get system info cpu_percent = psutil.cpu_percent() memory = psutil.virtual_memory() temp = psutil.sensors_temperatures()['cpu_thermal'][0].current # Display info draw.text((0, 0), f"CPU: {cpu_percent}%", font=font, fill=255) draw.text((0, 16), f"RAM: {memory.percent}%", font=font, fill=255) draw.text((0, 32), f"Temp: {temp}C", font=font, fill=255) oled.image(image) oled.show() time.sleep(2)
Scrolling Text
Create scrolling text effects for longer messages:
text = "This is a scrolling text message!" text_width = getfontsize(font, text)[0] for x in range(oled.width, -text_width, -1): draw.rectangle((0, 0, oled.width, oled.height), fill=0) draw.text((x, oled.height//2), text, font=font, fill=255) oled.image(image) oled.show() time.sleep(0.05)
Animated Graphics
Create simple animations using basic shapes:
for i in range(0, oled.width-10, 5): draw.rectangle((0, 0, oled.width, oled.height), fill=0) draw.rectangle((i, 20, i+10, 30), fill=255) # Moving rectangle oled.image(image) oled.show() time.sleep(0.1)
Multiple Pages
Create a multi-page display with button control:
pages = ["Page 1: Info", "Page 2: Stats", "Page 3: Graph"] current_page = 0 # Use buttons to change pages def next_page(): global current_page current_page = (current_page + 1) % len(pages) update_display()
Custom Fonts
Use different fonts for better visual appeal:
# Load custom font (requires font file) try: custom_font = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf", 12) except: custom_font = ImageFont.load_default()
Graphs and Charts
Display simple bar graphs or charts:
data = [10, 25, 45, 30, 60, 15] for i, value in enumerate(data): x = i * 20 + 5 height = int(value / 100 * oled.height) draw.rectangle((x, oled.height-height, x+15, oled.height), fill=255)
Conclusion
This project demonstrates how to interface with SSD1306 OLED displays using I2C communication on a Raspberry Pi. OLED displays provide crisp, high-contrast visual output suitable for various applications including system monitoring, user interfaces, and information displays. By combining text, shapes, and graphics, you can create informative and visually appealing displays for your projects. The skills learned here can be extended to create complex user interfaces, data visualizations, and real-time monitoring systems.
