1.5 Relay Control
In this project, we will learn how to control a relay module using a Raspberry Pi. Relays are electrically operated switches that allow low-power circuits to control high-power devices safely. This project demonstrates how to toggle a relay on and off at regular intervals.
What You’ll Need
To complete this project, you will need the following components:
COMPONENT
PURCHASE LINK
Jumper Wires
Resistor
LED
Transistor
Relay
Diode
Fusion HAT+
Raspberry Pi
Circuit Diagram
The GPIO signal passes through a 1 kΩ resistor to the transistor base, allowing the transistor to switch the relay coil on and off. When GPIO17 outputs HIGH, the transistor turns on, current flows through the relay coil, the relay activates, and the LED (through the 220 Ω resistor) lights up. When GPIO17 outputs LOW, the transistor turns off, the relay coil is de-energized, the relay releases, and the LED turns off. A flyback diode is placed across the relay coil to protect the circuit from voltage spikes.
../_images/1.3.3_relay_sch.png
Wiring Diagram
Follow these steps to build the circuit:
../_images/1.3.3_relay_bb.png
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory. Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 1.5_Relay.py
After running the script, the relay connected to GPIO 17 repeatedly switches on and off every second. When the relay is turned on, the console displays “Relay open
”, and when it is turned off, “
Relay close” is shown. This cycle continues until you press Ctrl + C, at which point the program stops and the relay is safely turned off.
The following Python code controls a relay module, toggling it on and off:
from fusion_hat.pin import Pin, Mode
from time import sleep  # Import the sleep function for delay
# Initialize the relay connected to GPIO pin 17
relay = Pin(17,mode=Mode.OUT)
    # Loop to continuously toggle the relay's state every second
        print('Relay open...')  # Inform that the relay is being activated
        relay.high()  # Turn on the relay
        sleep(1)   # Maintain the relay in the on state for 1 second
        print('...Relay close')  # Inform that the relay is being deactivated
        relay.low()  # Turn off the relay
        sleep(1)   # Maintain the relay in the off state for 1 second
    # Handle a keyboard interrupt (Ctrl+C) to exit the loop
    relay.off()  # Ensure the relay is turned off before exiting
This Python script controls a relay module connected to GPIO pin 17. When executed:
  1. The script enters an infinite loop that toggles the relay state every second
  2. When the relay is activated (HIGH), “Relay open
” is printed to the console
  3. When the relay is deactivated (LOW), “
Relay close” is printed to the console
  4. The program can be interrupted gracefully using Ctrl+C, which ensures the relay is turned off before exiting
Understanding the Code
  1. Library Import
    The Pin class from the fusion_hat library is used to control GPIO pins, and time.sleep introduces delays between state changes.
  2. Relay Initialization
    The relay is initialized on GPIO pin 17 and set to output mode.
  3. Main Control Loop
    The while True loop continuously toggles the relay state with 1-second intervals.
  4. Keyboard Interrupt Handling
    The try-except block ensures the program stops gracefully when interrupted (e.g., Ctrl+C), and turns off the relay before exiting.
Troubleshooting
  1. Relay Not Responding
    • Cause: Incorrect wiring or wrong GPIO pin configuration.
    • Solution: Verify all connections match the wiring diagram and confirm GPIO 17 is correctly specified.
  2. Relay Stays On or Off
    • Cause: Logic level mismatch or power supply issues.
    • Solution: Ensure the relay module is compatible with 3.3V logic levels and check that the power supply is adequate.
  3. Program Doesn’t Exit Cleanly
    • Cause: Keyboard interrupt not properly handled.
    • Solution: Make sure to use Ctrl+C to terminate the program and check that the exception handling code is present.
Extendable Ideas
  1. Scheduled Control
    Modify the code to control the relay based on a schedule, turning it on and off at specific times:
    import datetime
    # Turn relay on during specific hours
    current_time = datetime.datetime.now().time()
    if datetime.time(9, 0) <= current_time <= datetime.time(17, 0):
        relay.high()
        relay.low()
  2. Sensor-Activated Control
    Connect a sensor (like a temperature or motion sensor) and control the relay based on sensor readings:
    # Pseudocode for sensor-controlled relay
    if temperature_sensor.read() > 25:  # If temperature exceeds 25°C
        relay.high()  # Turn on cooling device
        relay.low()   # Turn off cooling device
  3. Multiple Relay Control
    Expand the project to control multiple relays simultaneously:
    # Initialize multiple relays
    relays = {
        'light': Pin(17, Pin.OUT),
        'fan': Pin(18, Pin.OUT),
        'pump': Pin(19, Pin.OUT)
    # Control individual relays
    relays['light'].high()
    relays['fan'].low()
Conclusion
This project demonstrates how to control a relay module using a Raspberry Pi. Relays are fundamental components in home automation, industrial control systems, and IoT applications. By mastering relay control, you can interface low-voltage circuits with high-power devices safely and effectively.
