2.6 Reed Switch
In this project, we will learn how to use a reed switch as a magnetic field sensor to control LEDs. A reed switch is an electrical switch operated by an applied magnetic field, commonly used in security systems, door/window sensors, and position detection. This project demonstrates how to detect the state of a reed switch and provide visual feedback using two LEDs.
What You’ll Need
To complete this project, you will need the following components:
COMPONENT
PURCHASE LINK
Jumper Wires
Reed Switch Module
LED
Resistor
Fusion HAT+
Raspberry Pi
Circuit Diagram
The circuit uses a reed switch connected to a GPIO input pin with a pull-down resistor. Two LEDs are connected to separate GPIO output pins, each with a current-limiting resistor. When a magnet approaches the reed switch, it closes the circuit, triggering the LED indicators to change states.
../_images/2.2.4_sch.png
Wiring Diagram
Follow these steps to build the circuit:
  1. Connect the GND & VCC pin of the reed switch to GND & 3.3V
  2. Connect the D0 Pin of the reed switch to GPIO 17
  3. Connect LED1 cathode to GPIO 22 through a 220Ω resistor
  4. Connect LED1 anode to GND
  5. Connect LED2 cathode to GPIO 27 through a 220Ω resistor
  6. Connect LED2 anode to GND
../_images/2.2.4_bb.png
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory. Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 2.6_ReedSwitch.py
This Python script creates a magnetic field detection system using a reed switch and two status LEDs. When executed:
  1. The script continuously monitors the state of the reed switch
  2. When a magnet is detected (reed switch closed), LED1 turns off and LED2 turns on
  3. When no magnet is detected (reed switch open), LED1 turns on and LED2 turns off
  4. This creates a clear visual indication of the magnetic field presence
  5. The program can be interrupted gracefully using Ctrl+C
The following Python code monitors a reed switch and controls two LEDs based on its state:
from time import sleep  # Import sleep for delay
# Initialize reed switch (Button) on GPIO pin 17
reed = Pin(17, mode=Mode.IN, pull=Pull.DOWN)
# Initialize LED1 connected to GPIO pin 22
led1 = Pin(22,mode=Mode.OUT)
# Initialize LED2 connected to GPIO pin 27
led2 = Pin(27,mode=Mode.OUT)
    # Continuously monitor the state of the reed switch and control LEDs accordingly
        if reed.value() == 0:  # Check if the reed switch is activated
            led1.off()  # Turn off LED1
            led2.on()   # Turn on LED2
        else:  # If the sensor is not activated
            led1.on()   # Turn on LED1
            led2.off()  # Turn off LED2
    # Handle a keyboard interrupt (Ctrl+C) for a clean exit from the loop
Understanding the Code
  1. Library Import
    The Pin class from the fusion_hat library is used to control GPIO pins, and time.sleep is imported for potential delay operations.
  2. Reed Switch Initialization
    The reed switch is initialized on GPIO pin 17 as an input with a pull-down resistor to ensure a stable LOW state when the switch is open.
  3. LED Initialization
    Two LEDs are initialized on GPIO pins 22 and 27 as outputs to provide visual feedback.
  4. Main Monitoring Loop
    The while True loop continuously checks the reed switch state and controls the LEDs accordingly, creating a clear status indication system.
  5. Keyboard Interrupt Handling
    The try-except block ensures the program stops gracefully when interrupted.
Troubleshooting
  1. Reed Switch Not Detecting Magnet
    • Cause: Magnet polarity issues, insufficient magnetic strength, or wiring problems.
    • Solution: Try flipping the magnet, use a stronger magnet, or verify all connections.
  2. LEDs Not Lighting
    • Cause: Incorrect GPIO pin assignments, LED polarity reversed, or insufficient current.
    • Solution: Check pin assignments, ensure LEDs are connected with correct polarity (anode to GPIO), and verify resistor values.
  3. Unstable Readings
    • Cause: Electrical noise or floating input when reed switch is open.
    • Solution: The built-in pull-down resistor should stabilize the input, but ensure proper grounding and check for nearby sources of electromagnetic interference.
Extendable Ideas
  1. Security System
    Create a simple door/window security alarm that triggers when a magnet moves away from the reed switch:
    # Add a buzzer for audible alarm
    from fusion_hat import Buzzer, PWM
    buzzer = Buzzer(PWM('P0'))
        if reed.value() == 1:  # Door opened (magnet moved away)
            buzzer.play('C6', 0.5)  # Sound alarm
            led1.on()  # Red alert LED
            led2.on()  # Green safe LED
        sleep(0.1)
  2. Position Counter
    Count how many times a magnet passes by the reed switch, useful for rotational speed measurement:
    counter = 0
    last_state = 0
        current_state = reed.value()
        if last_state == 0 and current_state == 1:  # Detect rising edge
            counter += 1
            print(f"Count: {counter}")
        last_state = current_state
        sleep(0.01)  # Short delay for debouncing
  3. Two-Sensor Detection
    Use two reed switches to detect direction of movement:
    reed1 = Pin(17, Pin.IN, pull=Pin.PULL_DOWN)
    reed2 = Pin(18, Pin.IN, pull=Pin.PULL_DOWN)
    # Determine direction based on which sensor triggers first
Conclusion
This project demonstrates how to use a reed switch as a magnetic field sensor to control LED indicators. Reed switches are reliable, simple components widely used in security systems, position sensing, and proximity detection applications. By combining magnetic sensing with visual feedback, you can create intuitive monitoring systems for various applications.
