2.1 Button
In this project, we will learn how to use a button to control an LED. Buttons are fundamental input devices used in various electronic projects to interact with circuits and systems.
What You’ll Need
To complete this project, you will need the following components:
COMPONENT
PURCHASE LINK
Jumper Wires
Resistor
LED
Button
Fusion HAT+
Raspberry Pi
Circuit Diagram
We will use a normally open button as an input for the Raspberry Pi. When the button is pressed, GPIO17 will receive a high-level signal (3.3V). The Raspberry Pi will detect this signal and turn the LED on. The circuit connections are shown in the diagrams below:
../_images/2.1.1_sch.png
Wiring Diagram
Follow these steps to build the circuit:
  1. Connect the anode (long pin) of the LED to a GPIO pin (GPIO22) through a current-limiting resistor.
  2. Connect the cathode (short pin) of the LED to the ground (GND).
  3. Connect one terminal of the button to GPIO17 and the other terminal to the ground (GND).
../_images/2.1.1_bb.png
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory. Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 2.1_Button.py
This Python script demonstrates an interactive setup where a button controls an LED. When executed:
  1. Pressing the button (connected to GPIO pin 17) turns the LED (connected to GPIO pin 22) on.
  2. Releasing the button turns the LED off.
  3. The program runs indefinitely, listening for button press and release events to control the LED.
The following Python code toggles the LED based on button presses and releases:
from signal import pause  # Import pause function from signal module
# Initialize an LED object on GPIO pin 22
led = Pin(22,mode=Mode.OUT)
# Initialize a Button object on GPIO pin 17
button = Pin(17, mode=Mode.IN, pull=Pull.DOWN)
# # Link the button's "when_activated" event to the LED's high() method
button.when_activated = led.high
# # Link the button's "when_deactivated" event to the LED's low() method
button.when_deactivated = led.low
# Run an event loop that waits for button events and keeps the script running
print("CTRL + C to exit")
pause()
Understanding the Code
  1. Library Import
    The fusion_hat library provides a simple interface for GPIO control, and the signal module is used to keep the program running.
  2. Component Initialization
    The LED is connected to GPIO pin 22, and the Button is connected to GPIO pin 17.
  3. Event Handling
    The when_activated and when_deactivated events are linked to the LED’s high() and low() methods, respectively. This ensures that the LED turns on when the button is pressed and off when the button is released.
  4. Event Loop
    The pause() function keeps the program running and listens for button press and release events.
    pause()
Troubleshooting
  1. LED Does Not Light Up
    • Cause: Incorrect GPIO pin connection or LED wiring.
    • Solution: Verify that the LED’s positive leg is connected to GPIO pin 22 and its negative leg to a resistor leading to ground.
  2. Button Press Has No Effect
    • Cause: Incorrect button wiring or GPIO pin configuration.
    • Solution: Ensure the button is connected correctly to GPIO pin 17 and ground. .
  3. LED Stays On or Off Regardless of Button State
    • Cause: The button may not trigger events correctly.
    • Solution: Check the button’s functionality by directly testing its connectivity with a multimeter or simple circuit.
Extendable Ideas
  1. Toggle LED State
    Modify the script to toggle the LED’s state with each button press instead of turning it on/off directly:
    def toggle():
       if led.value() == 1:
          led.off()
          led.on()
    button.when_activated = toggle
  2. Multiple LEDs
    Control multiple LEDs with a single button, cycling through different patterns:
    leds = [LED(17), LED(27), LED(22)]
    current_led = 0
    def cycle_leds():
       global current_led
       leds[current_led].off()
       current_led = (current_led + 1) % len(leds)
       leds[current_led].on()
    button.when_activated = cycle_leds
  3. Button Press Duration
    Add functionality to perform different actions based on how long the button is held:
    from time import time
    press_time = None
    def start_timer():
       global press_time
       press_time = time()
    def check_duration():
       global press_time
       duration = time() - press_time
       if duration < 2:
          led.on()
          led.off()
    button.when_activated = start_timer
    button.when_deactivated = check_duration
  4. Debouncing
    Implement software debouncing for more accurate button press detection:
    press_time = None
    debounce_time = 0.2
    def press():
       global press_time
       press_time = time()
    def debounce():
       global press_time
       current_time = time()
       duration = current_time - press_time
       if duration < debounce_time:
          return
          led.on()
    button.when_activated = press
    button.when_deactivated = debounce
Conclusion
This project demonstrates how to use a button to control an LED with a Fusion HAT+. Buttons are versatile components and can be integrated into various applications, from basic circuits to complex interactive systems.
