4.14 Gravity Cubeď
In this lesson, you will build a gravity-referenced 3D cube displayed on a 128Ă64 SSD1306 OLED, driven by an IMU. The cube tilts according to the boardâs orientation relative to gravity, using accelerometer-only roll and pitch.
Key features:
Orthographic 3D cube rendering (no perspective distortion)
Orientation derived from the accelerometer relative to an initial baseline
One cube face is filled to make front-back orientation easy to see
Two configuration flags let you flip X/Y directions to match your physical mounting
As you tilt the board, the cube rotates smoothly, giving an intuitive visualization of device orientation.
What Youâll Need
The following components are required for this project:
COMPONENT INTRODUCTION |
PURCHASE LINK |
Raspberry Pi |
Wiring Diagram
Refer to the wiring diagram for assembling the components:
Setup Steps
Install the OLED libraries:
sudo pip3 install adafruit-circuitpython-ssd1306 --break
Install the IMU libraries:
sudo pip install git+https://github.com/sunfounder/sunfounder-imu-python.git --break-system-packages
Run the example from the
ai-lab-kitdirectory:cd ~/ai-lab-kit/python/ sudo python3 4.14_Cube.py
When the script runs:
The accelerometer provides gravity-referenced X/Y/Z data.
The code computes roll and pitch relative to an initial baseline (current orientation becomes 0°, 0°).
A wireframe cube with a filled front face is drawn on the OLED.
Tilting the board rotates the cube on screen.
Press Ctrl+C to exit; the OLED is cleared.
Here is the Python script for the gravity-referenced cube:
import math
from PIL import Image, ImageDraw, ImageFont
import adafruit_ssd1306
import board
from sunfounder_imu import IMU
# ========== User-configurable axis flip ==========
# Flip X/Y to match your physical mounting and perceived motion on the OLED.
# If motion looks reversed on a given axis, set that axis to True.
FLIP_X = False # True = invert roll direction on display; False = normal
FLIP_Y = False # True = invert pitch direction on display; False = normal
# ========== OLED setup ==========
WIDTH, HEIGHT = 128, 64
i2c = board.I2C()
oled = adafruit_ssd1306.SSD1306_I2C(WIDTH, HEIGHT, i2c, addr=0x3C)
oled.fill(0)
oled.show()
# Framebuffer
image = Image.new("1", (WIDTH, HEIGHT))
draw = ImageDraw.Draw(image)
font = ImageFont.load_default()
# ========== IMU initialization ==========
imu = IMU()
# ========== Cube model ==========
CUBE_SIZE = 9 # smaller cube for 128x64 OLED
VERTS = [
(-1, -1, -1), (+1, -1, -1), (+1, +1, -1), (-1, +1, -1),
(-1, -1, +1), (+1, -1, +1), (+1, +1, +1), (-1, +1, +1),
EDGES = [
(0,1),(1,2),(2,3),(3,0),
(4,5),(5,6),(6,7),(7,4),
(0,4),(1,5),(2,6),(3,7)
FRONT_FACE = [4,5,6,7] # +Z face gets filled
# ========== Projection (orthographic) ==========
def project_point(p, scale=CUBE_SIZE, cx=WIDTH//2, cy=HEIGHT//2):
Orthographic projection. We flip the screen Y here so that positive 3D Y
appears upward on the OLED (more intuitive for tilt).
x, y, _z = p
return int(cx + scale * x), int(cy - scale * y)
# ========== Math / orientation helpers ==========
def ema(prev, new, alpha):
"""Exponential smoothing to reduce jitter."""
return alpha * new + (1.0 - alpha) * prev
def rotate_point(p, roll, pitch, yaw=0.0):
"""Rotate p=(x,y,z) by Rx(roll)*Ry(pitch)*Rz(yaw). Yaw fixed to 0 for gravity-only."""
x, y, z = p
# Rx
cr, sr = math.cos(roll), math.sin(roll)
y, z = (y*cr - z*sr), (y*sr + z*cr)
# Ry
cp, sp = math.cos(pitch), math.sin(pitch)
x, z = (x*cp + z*sp), (-x*sp + z*cp)
# Rz (kept for completeness)
if yaw:
cz, sz = math.cos(yaw), math.sin(yaw)
x, y = (x*cz - y*sz), (x*sz + y*cz)
return (x, y, z)
def accel_to_rp(ax, ay, az):
Convert accelerometer (m/s²) to roll/pitch in radians (gravity-referenced).
roll = rotation around X (right-hand rule)
pitch = rotation around Y
# Convert from m/s² to g (9.80665 m/s² = 1g)
ax_g = ax / 9.80665
ay_g = ay / 9.80665
az_g = az / 9.80665
g = math.sqrt(ax_g*ax_g + ay_g*ay_g + az_g*az_g) + 1e-9
axn, ayn, azn = ax_g / g, ay_g / g, az_g / g
roll = math.atan2(ayn, azn)
pitch = math.atan2(-axn, math.sqrt(ayn*ayn + azn*azn))
return roll, pitch
def draw_cube(roll, pitch, yaw=0.0, annotate=True):
"""Render the cube with one filled face."""
draw.rectangle((0, 0, WIDTH, HEIGHT), outline=0, fill=0)
rverts = [rotate_point(v, roll, pitch, yaw) for v in VERTS]
pts = [project_point(v) for v in rverts]
# Filled front face
face_xy = [pts[i] for i in FRONT_FACE]
draw.polygon(face_xy, outline=255, fill=255)
# Wireframe edges
for a, b in EDGES:
x0, y0 = pts[a]
x1, y1 = pts[b]
draw.line((x0, y0, x1, y1), fill=255)
if annotate:
rdeg = math.degrees(roll)
pdeg = math.degrees(pitch)
draw.text((2, 2), f"R:{rdeg:+.0f} P:{pdeg:+.0f}", font=font, fill=255)
# ========== Baseline & smoothing ==========
baseline_set = False
roll0 = pitch0 = 0.0
ROLL_EMA = 0.20
PITCH_EMA = 0.20
roll_disp = pitch_disp = 0.0
# Read IMU data
data = imu.read()
# Extract accelerometer data (in m/s²)
ax = data['accel_x']
ay = data['accel_y']
az = data['accel_z']
# Absolute roll/pitch from gravity
roll_abs, pitch_abs = accel_to_rp(ax, ay, az)
# First reading defines baseline (0°,0°)
if not baseline_set:
roll0, pitch0 = roll_abs, pitch_abs
baseline_set = True
# Relative orientation
roll_rel = roll_abs - roll0
pitch_rel = pitch_abs - pitch0
# Apply user flips to match perceived direction on OLED
if FLIP_X:
roll_rel = -roll_rel
if FLIP_Y:
pitch_rel = -pitch_rel
# Smooth
roll_disp = ema(roll_disp, roll_rel, ROLL_EMA)
pitch_disp = ema(pitch_disp, pitch_rel, PITCH_EMA)
# Render (yaw fixed to 0 in gravity-only mode)
draw_cube(roll_disp, pitch_disp, yaw=0.0, annotate=True)
# Show on OLED
oled.image(image)
oled.show()
time.sleep(0.02)
oled.fill(0)
oled.show()
print("\nExited.")
Understanding the Code
IMU Initialization
The script creates an
IMUinstance from the Fusion HAT+ module. The accelerometer provides raw X, Y, Z acceleration values in units of m/s².Gravity-Referenced Angles
accel_to_rp()converts the accelerometer readings into roll and pitch:Roll: rotation around the X axis
Pitch: rotation around the Y axis
Only gravity is used, so yaw cannot be determined (and is fixed to 0).
def accel_to_rp(ax, ay, az): """ Convert accelerometer (m/s²) to roll/pitch in radians (gravity-referenced). roll = rotation around X (right-hand rule) pitch = rotation around Y """ # Convert from m/s² to g (9.80665 m/s² = 1g) ax_g = ax / 9.80665 ay_g = ay / 9.80665 az_g = az / 9.80665 g = math.sqrt(ax_g*ax_g + ay_g*ay_g + az_g*az_g) + 1e-9 axn, ayn, azn = ax_g / g, ay_g / g, az_g / g roll = math.atan2(ayn, azn) pitch = math.atan2(-axn, math.sqrt(ayn*ayn + azn*azn)) return roll, pitch
Baseline Orientation
On the very first reading:
The current
rollandpitchare stored as baseline (roll0,pitch0).Subsequent orientations are expressed as relative angles:
roll_rel = roll_abs - roll0 pitch_rel = pitch_abs - pitch0
This way, the deviceâs initial position becomes 0°, 0°.
User-Configurable Axis Flip
The two flags
FLIP_XandFLIP_Yallow you to invert motion on each axis:Set
FLIP_X = Trueif roll feels reversed on the displaySet
FLIP_Y = Trueif pitch feels reversed
This is helpful if your IMU is rotated or wired in a different orientation.
Smoothing (EMA)
The function
ema()applies exponential moving average smoothing:Reduces jitter caused by sensor noise
Makes cube motion look more natural
ROLL_EMAandPITCH_EMAcontrol how responsive vs. smooth the motion is.def ema(prev, new, alpha): """Exponential smoothing to reduce jitter.""" return alpha * new + (1.0 - alpha) * prev
3D Cube Rotation
rotate_point()applies rotation matrices to each cube vertex:def rotate_point(p, roll, pitch, yaw=0.0): """Rotate p=(x,y,z) by Rx(roll)*Ry(pitch)*Rz(yaw). Yaw fixed to 0 for gravity-only.""" x, y, z = p # Rx cr, sr = math.cos(roll), math.sin(roll) y, z = (y*cr - z*sr), (y*sr + z*cr) # Ry cp, sp = math.cos(pitch), math.sin(pitch) x, z = (x*cp + z*sp), (-x*sp + z*cp) # Rz (kept for completeness) if yaw: cz, sz = math.cos(yaw), math.sin(yaw) x, y = (x*cz - y*sz), (x*sz + y*cz) return (x, y, z)
Rx(roll)followed byRy(pitch)(yaw kept at 0)Produces rotated 3D coordinates
project_point()then converts 3D coordinates to 2D OLED positions using orthographic projection.def project_point(p, scale=CUBE_SIZE, cx=WIDTH//2, cy=HEIGHT//2): """ Orthographic projection. We flip the screen Y here so that positive 3D Y appears upward on the OLED (more intuitive for tilt). """ x, y, _z = p return int(cx + scale * x), int(cy - scale * y)
Drawing the Cube
draw_cube():Clears the screen
Rotates and projects all 8 cube vertices
Draws all edges as a wireframe
Fills one face (
FRONT_FACE) so you can easily see which side is pointing toward youOptionally shows roll and pitch in degrees at the top left
def draw_cube(roll, pitch, yaw=0.0, annotate=True): """Render the cube with one filled face.""" draw.rectangle((0, 0, WIDTH, HEIGHT), outline=0, fill=0) rverts = [rotate_point(v, roll, pitch, yaw) for v in VERTS] pts = [project_point(v) for v in rverts] # Filled front face face_xy = [pts[i] for i in FRONT_FACE] draw.polygon(face_xy, outline=255, fill=255) # Wireframe edges for a, b in EDGES: x0, y0 = pts[a] x1, y1 = pts[b] draw.line((x0, y0, x1, y1), fill=255) if annotate: rdeg = math.degrees(roll) pdeg = math.degrees(pitch) draw.text((2, 2), f"R:{rdeg:+.0f} P:{pdeg:+.0f}", font=font, fill=255)
Troubleshooting
Cube does not move
Confirm I2C is enabled on Raspberry Pi.
Verify the correct I2C address is used by your IMU driver.
Motion looks reversed
Toggle
FLIP_XorFLIP_Yto invert directions.Try placing the board flat, then slowly tilt along one axis to identify which flip is needed.
Cube is too jittery
Increase smoothing by lowering
ROLL_EMA/PITCH_EMA(e.g., 0.1).Make sure the board is mechanically stable and cables are not tugging it.
Cube tilts when resting flat
Hold the board steady and restart the script; the initial reading becomes the baseline.
Ensure the board is truly flat when the program starts.
OLED shows nothing
Check OLED I2C address (commonly
0x3C).Verify wiring and that the display contrast is adequate.
Confirm that
adafruit-circuitpython-ssd1306is installed.
Try It Yourself
Add Yaw from Gyro
Combine gyro integration with accelerometer data (a complementary filter) to add a yaw axis and allow full 3D cube rotation.
Change Cube Size or Position
Adjust
CUBE_SIZEor the projection center to move the cube or make it larger/smaller:Zoom in for a more dramatic effect
Shift it slightly upward to leave more room for text
Add a Wireframe Grid
Draw a simple âfloorâ grid behind the cube to emphasize 3D motion.
Add Auto-Recenter Function
Long-press a button (or use a key input) to reset the baseline orientation during runtime.
Multiple Display Modes
Toggle between:
Wireframe only
Filled face only
Face shading based on tilt angle
These enhancements turn the simple gravity cube into a rich 3D IMU visualization tool.
