1.3 Active Buzzerï
In this project, we will learn how to drive an active buzzer to produce a beeping sound using a NPN transistor. Active buzzers are simple components used in many electronic projects to produce sound signals.
What Youâll Need
To complete this project, you will need the following components:
COMPONENT |
PURCHASE LINK |
Raspberry Pi |
Circuit Diagram
The circuit uses an active buzzer, a NPN transistor, and a 1kΩ resistor. The resistor protects the transistor by limiting the base current. When GPIO17 outputs a high level (3.3V), the transistor conducts, allowing current to flow through the buzzer, causing it to beep. When GPIO17 outputs a low level, the transistor is cut off, and the buzzer remains silent.
Wiring Diagram
Follow these steps to build the circuit:
Place the NPN transistor, buzzer, and resistor on the breadboard.
Connect the base of the transistor to GPIO17 through the resistor.
Connect the emitter of the transistor to the power supply (+).
Connect the collector of the transistor to one terminal of the buzzer.
Connect the other terminal of the buzzer to the ground (-).
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory.
Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 1.3_ActiveBuzzer.py
This Python script controls a buzzer connected to GPIO pin 17 on a Raspberry Pi. When executed:
The buzzer alternates between turning on and off every 0.1 seconds, producing a beeping sound.
The program prints âBuzzer Onâ and âBuzzer Offâ to the console in sync with the buzzerâs operation.
The buzzing continues indefinitely until the user interrupts the script by pressing
Ctrl+C.
The following Python code drives the active buzzer to beep on and off in a loop:
from fusion_hat.modules import Buzzer
from fusion_hat.pin import Pin
from time import sleep
# Initialize a Buzzer object on GPIO pin 17
buzzer = Buzzer(Pin(17))
# Turn on the buzzer
print('Buzzer On')
buzzer.on()
sleep(0.1) # Keep the buzzer on for 0.1 seconds
# Turn off the buzzer
print('Buzzer Off')
buzzer.off()
sleep(0.1) # Keep the buzzer off for 0.1 seconds
# Handle KeyboardInterrupt (Ctrl+C) for clean script termination
After running the script, the buzzer connected to the Raspberry Pi will repeatedly beep by turning on and off every 0.1 seconds. At the same time, the console will display âBuzzer Onâ and âBuzzer Offâ messages that match the buzzerâs sound. The buzzer will keep beeping until you stop the program by pressing Ctrl + C.
Understanding the Code
Library Import
The
fusion_hatlibrary provides an easy-to-use interface for controlling GPIO pins, andtimeis used for delays.from fusion_hat.modules import Buzzer from fusion_hat.pin import Pin from time import sleep
Buzzer Initialization
The
Buzzerobject is initialized and associated with Pin 17.buzzer = Buzzer(Pin(17))
Control Loop
The program uses an infinite loop (
while True) to toggle the buzzer on and off every 0.1 seconds, creating a beeping sound. Theprintstatements provide console feedback.while True: print('Buzzer On') buzzer.on() sleep(0.1) print('Buzzer Off') buzzer.off() sleep(0.1)
Keyboard Interrupt Handling
The
try-exceptblock ensures that the program can be terminated cleanly using Ctrl+C without raising errors.except KeyboardInterrupt: pass
Troubleshooting
No Sound from the Buzzer
Cause: Incorrect GPIO pin connection or buzzer wiring.
Solution: Ensure the buzzer is properly connected to GPIO pin 17 and the ground (GND).
Buzzer Always On or Off
Cause: Faulty buzzer or GPIO setup issue.
Solution: Verify the buzzerâs functionality by testing it with direct voltage.
Script Doesnât Respond to KeyboardInterrupt
Cause: The
exceptblock may not properly handle interruption.Solution: Ensure the
try...except KeyboardInterruptblock is properly implemented, and that no other processes are blocking the main loop.
Buzzing is Too Fast or Annoying
Cause: The
sleep(0.1)interval may be too short.Solution: Increase the
sleep()duration for longer intervals between buzzes.
Extendable Ideas
Custom Beep Patterns Create distinct beep patterns for different events or notifications:
def beep_pattern(): buzzer.on() sleep(0.3) buzzer.off() sleep(0.1) buzzer.on() sleep(0.1) buzzer.off()
User Input for Buzzer Control Allow the user to start, stop, or change the buzzerâs pattern dynamically:
while True: command = input("Enter 'on', 'off', or 'pattern': ") if command == 'on': buzzer.on() elif command == 'off': buzzer.off() elif command == 'pattern': beep_pattern()
Conclusion
This project demonstrates how to drive an active buzzer using a NPN transistor and the Raspberry Pi GPIO pins. The simplicity of the code and hardware setup makes it a great starting point for sound-based electronic projects.
