4.16 Pan-Tilt Camera Control System
In this project, you will create a camera control system that can pan (move horizontally) and tilt (move vertically) using a joystick. The system allows you to remotely control the direction of a camera mounted on servos, preview the camera feed in real-time, and capture photos with the press of the joystick button. This project is perfect for surveillance applications, photography projects, or learning about servo motor control and camera integration.
What You’ll Need
The following components are required for this project:
COMPONENT INTRODUCTION
PURCHASE LINK
Jumper Wires
Servo
Joystick Module
Camera Module
Fusion HAT+
Raspberry Pi
Circuit Diagram
../_images/2.1.9_sch.png
Wiring Diagram
  1. To use camera module conveniently, Assemble the Pan-tilt (For Camera) is recommended.
    Assembling the pan-tilt may obscure some pins, so it is recommended to assemble it only when using the camera, or place it on the outside after assembly.
    ../_images/gimbal_assemble.png
  2. Follow this wiring diagram to set up the circuit:
    ../_images/4.16_joystick_camera_bb.png
Running the Example
  1. Access the Raspberry Pi Desktop:
  2. Open a Terminal and go to the code folder:
    cd ~/ai-lab-kit/python
  3. Run the script to start the camera:
    sudo python3 pan_tilt_camera.py
  4. After running the script, the pan-tilt camera system starts and initializes the camera and servos.
    • If a display is available, a live camera preview is shown; otherwise, the program runs normally in headless mode.
    • Moving the joystick left or right rotates the camera horizontally (pan), while moving it up or down tilts the camera vertically (tilt).
    • When the joystick button is pressed, the camera captures a photo and saves it to the Pictures/camera_pan_tilt directory using a simple sequential filename such as photo_001.jpg.
    • The system continues running and responding to user input until you stop the program by pressing Ctrl + C.
Below is the Python script used in this project:
import os, time
from fusion_hat.adc import ADC
from fusion_hat.servo import Servo
# Servo channels for pan (horizontal) and tilt (vertical)
PAN_CHANNEL, TILT_CHANNEL = 2, 3
# Joystick ADC pins (X/Y axis) and button pin
X_PIN, Y_PIN = "A1", "A0"
BTN_PIN = 17
# Angle limits to protect servos
PAN_MIN, PAN_MAX = -90, 90
TILT_MIN, TILT_MAX = -45, 45
# Deadzone ignores small joystick movement
DEADZONE = 15
MOVE_SPEED = 3
LOOP_DELAY = 0.05
# Photo save directory (works with sudo)
REAL_USER = os.getenv("SUDO_USER") or os.getlogin()
PHOTO_DIR = os.path.join(f"/home/{REAL_USER}", "Pictures", "camera_pan_tilt")
os.makedirs(PHOTO_DIR, exist_ok=True)
# Initialize servos
pan_servo = Servo(PAN_CHANNEL)
tilt_servo = Servo(TILT_CHANNEL)
# Initialize joystick and button (active-low)
x_adc = ADC(X_PIN)
y_adc = ADC(Y_PIN)
joystick_button = Pin(BTN_PIN, mode=Mode.IN, pull=Pull.UP)  # pressed -> 0
# Initialize camera
camera = Picamera2()
camera.configure(camera.create_preview_configuration(main={"size": (1280, 720)}))
preview_started = False
photo_count = 1
current_pan = 0
current_tilt = 0
last_button_state = 1  # Used for edge detection
def clamp(v, vmin, vmax):
    # Limit value to a safe range
    return max(vmin, min(vmax, v))
def map_value(value, in_min, in_max, out_min, out_max):
    # Map ADC value to a new range
    return (value - in_min) * (out_max - out_min) / (in_max - in_min) + out_min
def apply_deadzone(v, dz):
    # Ignore small joystick movement
    return 0 if (-dz < v < dz) else v
def read_joystick():
    # Read joystick X/Y position
    x = map_value(x_adc.read(), 0, 4095, -100, 100)
    y = map_value(y_adc.read(), 0, 4095, -100, 100)
    return x, y
def check_button_press():
    # Detect button press (HIGH -> LOW)
    global last_button_state
    current_state = joystick_button.value()
    if last_button_state == 1 and current_state == 0:
        last_button_state = current_state
        return True
    return False
def take_photo():
    # Capture and save one photo
    global photo_count
    filename = f"photo_{photo_count:03d}.jpg"
    filepath = os.path.join(PHOTO_DIR, filename)
    camera.capture_file(filepath)
    print("Saved:", filepath)
    photo_count += 1
def start_preview_if_available():
    # Start camera preview only if a display is available
    global preview_started
    if os.getenv("DISPLAY"):
            camera.start_preview(Preview.QT)
            preview_started = True
        except Exception:
def cleanup():
    # Safely stop camera and release resources
        camera.stop()
    except Exception:
    if preview_started:
            camera.stop_preview()
        except Exception:
        camera.close()
    except Exception:
def main():
    global current_pan, current_tilt
    camera.start()
    # Center camera at startup
    pan_servo.angle(0)
    tilt_servo.angle(0)
            # Read joystick and move camera
            x, y = read_joystick()
            x = apply_deadzone(x, DEADZONE)
            y = apply_deadzone(y, DEADZONE)
            new_pan = current_pan + (MOVE_SPEED if x > DEADZONE else -MOVE_SPEED if x < -DEADZONE else 0)
            new_tilt = current_tilt + (MOVE_SPEED if y > DEADZONE else -MOVE_SPEED if y < -DEADZONE else 0)
            new_pan = clamp(new_pan, PAN_MIN, PAN_MAX)
            new_tilt = clamp(new_tilt, TILT_MIN, TILT_MAX)
            if new_pan != current_pan:
                current_pan = new_pan
                pan_servo.angle(current_pan)
            if new_tilt != current_tilt:
                current_tilt = new_tilt
                tilt_servo.angle(current_tilt)
            # Take photo when button is pressed
            if check_button_press():
                take_photo()
            time.sleep(LOOP_DELAY)
    finally:
        cleanup()
if __name__ == "__main__":
    main()
Understanding the Code
  1. Hardware Initialization
    • Two servo motors are initialized to control camera pan (horizontal) and tilt (vertical) movement
    • The joystick uses ADC channels to read X and Y analog values, and a GPIO pin to detect button presses
    • The camera module is initialized and configured for preview mode, supporting both display and headless operation
  2. Joystick Reading and Processing
    • read_joystick() reads raw analog values from the joystick’s X and Y axes
    • map_value() converts ADC values (0–4095) into a usable range of −100 to 100
    • apply_deadzone() filters out small joystick movements to prevent unwanted camera drift
  3. Camera Movement Control
    • Joystick input is translated into incremental changes in pan and tilt angles
    • clamp() ensures the angles stay within safe limits to protect the servo motors
    • Servos are updated only when the angle changes, providing smooth and stable motion
  4. Button Press Detection
    • The joystick button is configured as an active-low input using a pull-up resistor
    • check_button_press() detects a button press using edge detection (HIGH → LOW)
    • This ensures only one photo is taken per button press, even if the button is held
  5. Photo Capture and Storage
    • take_photo() captures an image using the camera module
    • Photos are saved with sequential filenames (for example, photo_001.jpg)
    • All images are stored in the user’s Pictures/camera_pan_tilt directory
  6. Camera Preview Handling
    • A live camera preview is started only when a graphical display is available
    • The script continues to function normally when running without a display
  7. Main Loop and Cleanup
    • The main loop continuously reads joystick input and responds in real time
    • When the program exits using Ctrl + C, the camera is safely stopped
    • All hardware resources are properly released to ensure a clean shutdown
Troubleshooting
  1. Servos Not Moving:
    • Cause: Incorrect servo connections or power issues
    • Solution:
      • Verify servos are connected to correct channels (2 and 3)
      • Ensure Fusion HAT is properly powered
      • Check servo wiring for loose connections
  2. Camera Preview Not Showing:
    • Cause: Camera module not detected or incorrect configuration
    • Solution:
      • Ensure camera cable is securely connected to CSI port
      • Check if camera is enabled in Raspberry Pi configuration
      • Verify camera module compatibility
  3. Joystick Not Responding:
    • Cause: Incorrect pin assignments or ADC issues
    • Solution:
      • Verify joystick connections to A0, A1, and GPIO 17
      • Test ADC readings with simple print statements
      • Check if Fusion HAT ADC is functioning
  4. Photos Not Saving:
    • Cause: Permission issues or directory problems
    • Solution:
      • Check if Pictures directory exists in user’s home
      • Verify write permissions for the photo directory
      • Try running with sudo if permission issues persist
  5. Erratic Servo Movement:
    • Cause: Power fluctuations or software timing issues
    • Solution:
      • Ensure stable power supply to Fusion HAT
      • Adjust MOVE_SPEED and delay values
      • Add capacitors to servo power lines if needed
Extendable Ideas
  1. Video Recording: Add video recording functionality with start/stop control:
    def start_recording():
        timestamp = time.strftime("%Y%m%d_%H%M%S")
        video_path = os.path.join(VIDEO_DIR, f"video_{timestamp}.mp4")
        camera.start_recording(video_path)
        print(f"Recording started: {video_path}")
    def stop_recording():
        camera.stop_recording()
        print("Recording stopped")
  2. Preset Positions: Create preset camera positions for quick access:
    PRESETS = {
        'center': (0, 0),
        'left': (-45, 0),
        'right': (45, 0),
        'up': (0, 30),
        'down': (0, -30)
    def goto_preset(preset_name):
        if preset_name in PRESETS:
            pan, tilt = PRESETS[preset_name]
            pan_servo.angle(pan)
            tilt_servo.angle(tilt)
Conclusion
This project demonstrates how to create a sophisticated pan-tilt camera control system using Raspberry Pi, servos, and a camera module. It combines hardware control, real-time video processing, and user input handling into a cohesive system. The project provides a foundation for more advanced applications like surveillance systems, photography robots, or interactive art installations.
