2.7 PIR Sensor
The Passive Infrared (PIR) sensor is a motion detection device that senses infrared radiation emitted by humans and animals. In this project, we will use the PIR sensor to detect motion.
What You’ll Need
Below are the components required for this project:
COMPONENT INTRODUCTION
PURCHASE LINK
PIR Motion Sensor Module
Jumper Wires
Fusion HAT+
Raspberry Pi
Circuit Diagram
Below is the schematic diagram for this project:
../_images/2.2.6_sch.png
Wiring Diagram
Build the circuit as shown in the diagram below:
../_images/2.2.6_bb.png
Ensure the RGB LED and PIR sensor are connected to the correct GPIO pins as per the schematic.
Adjust the two potentiometers on the PIR module for optimal sensitivity and detection distance. Turn both counterclockwise to their maximum setting for best results.
../_images/PIR_TTE.png
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory. Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 2.7_PIR.py
This Python script monitors a PIR (Passive Infrared) motion sensor based on motion detection. When executed:
  1. When Motion is Detected: Prints “Detected Barrier!” to the console.
  2. When No Motion is Detected: Prints “No Barrier” to the console.
  3. The program runs indefinitely, waiting for motion events. It can be terminated by pressing Ctrl+C.
Below is the Python code for this project:
from signal import pause  # Import pause function from signal module
# Initialize a PIR Module object on GPIO pin 17
pir = Pin(17, mode=Mode.IN, pull=Pull.DOWN)
def detect():
   if pir.value() == 1:  # Check if the PIR Module is triggered
      print("Detected Barrier!")
      print("No Barrier")
   pir.when_activated = detect  # Set up an interrupt to detect changes in the pir sensor state
   pir.when_deactivated = detect
   # Run an event loop that waits for button events and keeps the script running
   print("CTRL + C to exit")
   pause()
   # Handle KeyboardInterrupt (Ctrl+C) to exit the loop gracefully
Understanding the Code
  1. Imports:
    The script uses the fusion_hat library to control the PIR sensor, and the signal module to handle program termination.
  2. Initialization:
    In this line, a PIR sensor is initialized on pin 17 with an internal pull-down resistor enabled.
  3. Main Loop:
    def detect():
          print("No Barrier")
       pause()
    • Continuously checks for motion detected by the PIR sensor.
    • If motion is detected, the message “Detected Barrier!” is printed.
    • If no motion is detected, the message “No Barrier” is printed.
Troubleshooting
  1. Motion Not Detected:
    • Cause: PIR sensor is not wired or configured properly.
    • Solution:
      • Ensure the PIR sensor is connected to GPIO pin 17, power, and ground.
      • Adjust the sensor’s sensitivity and delay potentiometers if available.
Extendable Ideas
  1. Auditory Feedback: Add a buzzer that sounds when motion is detected:
    from fusion_hat import Buzzer
    buzzer = Buzzer(Pin(22))
       buzzer.on()
       buzzer.off()
  2. Data Logging: Log motion detection events with timestamps to a file for analysis:
    with open("motion_log.txt", "a") as log_file:
       log_file.write(f"Motion detected at {time.time():.3f}\n")
Conclusion
This project demonstrates how to use a PIR sensor. By understanding the basics of motion sensing control, you can expand this project into more advanced applications such as security systems, automated lighting, or interactive devices. The PIR sensor’s versatility and simplicity make it an excellent component for countless DIY and professional projects.
