1.6 Motor
In this project, we will learn how to use the Fusion HAT+ to control a DC motor, making it rotate clockwise and counterclockwise.
What You’ll Need
To complete this project, you will need the following components:
COMPONENT |
PURCHASE LINK |
Raspberry Pi |
Circuit Diagram
The circuit diagram below shows the connections required to control the motor.
Wiring Diagram
Running the Example
All example code used in this tutorial is available in the ai-lab-kit directory.
Follow these steps to run the example:
cd ~/ai-lab-kit/python/
sudo python3 1.6_Motor.py
After running the script, the motor connected to port M0 repeatedly starts and stops in a loop. It first stops for 0.5 seconds, then runs at −50% power for 1 second, stops again for 0.5 seconds, and finally runs at 75% power for 1 second. This sequence repeats continuously. When the program exits, the motor is safely stopped.
The following Python code controls the motor’s rotation direction and timing:
from time import sleep
from fusion_hat.motor import Motor
# Motor on port M0, reverse direction if needed
motor = Motor("M0", is_reversed=True)
motor.power(0)
sleep(0.5)
motor.power(-50)
sleep(1)
motor.power(0)
sleep(0.5)
motor.power(75)
sleep(1)
# Ctrl + C to stop
print("\nStopped by user.")
finally:
# Always stop the motor safely
motor.stop()
sleep(0.1)
Understanding the Code
Library Import
The
fusion_hatlibrary simplifies GPIO interactions, while thetimelibrary provides delay functions.from time import sleep from fusion_hat.motor import Motor
Motor Initialization
The
Motorobject is created using M0 pins.motor = Motor('M0', is_reversed=True)
Motor Actions
The motor speed is set to 0, -50, and 75, respectively. The
sleepfunction pauses the program for a specified duration.try: # Loop forever while True: motor.power(0) # Stop the motor sleep(0.5) # Wait 0.5 seconds motor.power(-50) # Run the motor at -50% power sleep(1) # Run for 1 second motor.power(0) # Stop again sleep(0.5) # Wait 0.5 seconds motor.power(75) # Run the motor at 75% power sleep(1) # Run for 1 second
Troubleshooting
Motor Does Not Move
Cause: Incorrect wiring or GPIO pin configuration.
Solution: Ensure the motor is receiving power and the enable pin is connected properly.
Only One Direction Works
Cause: Faulty connection to the forward or backward pin.
Solution: Ensure the pins are securely connected to the Fusion HAT+.
Motor Spins Continuously Without Stopping
Cause: The
stop()function may not be executed properly.Solution: Confirm that the
motor.stop()method is called.
Extendable Ideas
User-Controlled Actions
Allow the user to control the motor in real-time via keyboard input:
while True: num = int(input("The speed percentage (-100~100): ")) if num >= -100 and num <= 100: motor.speed(num) else: print("Invalid action!")
Timed Motor Control
Add functionality to run the motor for a user-specified duration:
duration = int(input("Enter duration (seconds): ")) motor.speed(50) sleep(duration) motor.stop()
Conclusion
This project demonstrates how to control a DC motor using the Fusion HAT+. Understanding motor control is essential for building robotics and other motion-based electronic projects.
